AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Comcast remote codes for Sharp TV
post #1 of 3
I have the Comcast working for everything but the On Demand. I can view OD, but I can't select using the A/B/C buttoms on the remote. They don't respond.
I am using setup code 11602 for the Sharp model 46D64U.
Are there additional codes for controlling the A/B/C keys on the Comcast remote? These buttons are used when entering On Demand. I think they were disabled when I did a factory reset of the remote.
post #2 of 3
The Comcast website has manuals for their remotes buried in their support section... I've always used 10093 (previously 0093) for Sharp TVs for several years now.
post #3 of 3
Despite the title of your post, you're not asking for a sharp code, right? You just want to get A/B/C back. As you've guessed, the reset may have wiped out the comcast upgrade. So you have a few options: exchange your remote for another one, post the model of your cable box and someone may be able to give you the codes for just the missing buttons, or buy/build a JP1 cable and load the upgrade back in yourself. Option one is free. Option three will cost $15-$30 and a few hours figuring out what to do and installing some software. Post over at the hifi-remote.com forums to find the cable and file you need, if you go with the third option. The benefit of the third option is that, once you have a cable and understand the software, you can make that remote do just about anything. I'm also assuming your remote has a 6-pin connector in the battery bay. If it doesn't, then option three and probably option two are off the table.
  Back to Forum: Remote Control Area
