The Vizio soundbar only works with PCM from the digital (optical) output of your TV. You would need to first check to see what type of audio output comes from your television. Second, some TV's, only send output to the digital connection when you either power off the internal speakers or set the TV to Home Theater (or similar) mode.
post #121 of 141
12/18/10 at 12:47pm
