Lots has happened to my basement since this thread has started. Here are the most recent sketches (as of 11/25/2009):
http://www.avsforum.com/avs-vb/showt...7#post17604057
Original first post and outdated pics & images:
Well -- after nearly a year of thinking about it, the time has come to start work on the basement theater and bar. I will be doing most of the work myself. The left portion of the basement is already finished. The bottom right was finished off as a room, but those walls will need to be torn down.
The screen will be going over an entrance to a crawlspace, so it will either need to be retractable, removable, or hinged. I am leaning toward hinged.
The ceiling is mostly drop ceiling except for the hvac runs (down the middle) which is drywall.
Here is an obligatory sketchup:
With more views here:
http://www.screencast.com/t/fJ0pMNphwh
http://www.screencast.com/t/GqVJ2RKjicr
http://www.screencast.com/t/bLxmAEhS
Components I already have:
Components needed going forward:
Finally, here is a link to my original exploration thread. It's dated, but that it what I started with... http://www.avsforum.com/avs-vb/showthread.php?t=1008869
- Pioneer VSX-01TXH Elite Receiver
- Panasonic Viera 42" 1080p Plasma (will go upstairs once projector & screen is installed)
- JBL Studio L Series Speakers (L890 Mains, L820 Surrounds, LC2 Center, & L8400P sub)
- Samsung BDP-1500 BluRay Player
- Custom Built HTPC running SageTV client w/ HDMI out attached to media server
- Wii
- Harmony 890 Universal Remote (w/ RF)
- 12' Shuffleboard table & arcade games
- Projector (will be one of Panasonic, Epson, Mitsubishi 1080p)
- Screen (will likely be 100" & 16x9 format)
- Remote Lighting control
- Another set of L820 for rear surrounds
- Furniture (likely narrow Berklines -- i think its the 086 or 088 series) Will get one row for starters, perhaps add a second row with riser & bar if space (and money) permits
- Gas fireplace / pellet stove / other heat source
.png)
.jpg)
Fellow michigander.
Anyhow, you'd probably like my shuffleboard table better seeing how it has crimson felt on it! (At least my Dad (OSU alum) does)...
) So just food for thought.
