AVS › AVS Forum › HDTV › HDTV Technical › The green bar behind the caption
post #1 of 2
since I am turning the caption on, there are always green bar behind caption, it used to be fine, just happened these 2 days, and no problem for reg def channels! somebody help?
post #2 of 2
Closed captioning formatting is handled by your STB, IRD or TV, depending on which you have. You have changed some setting.
  Back to Forum: HDTV Technical
