hi guys
just installed my brand new sub 12 studio.
i tried to pbk it as i had the kit included in the price
no problem to install it on the laptop, software works, and both sub and mic are correctly detected both by laptop and paradigm pbk software
when i go to Tools and quick measure then the sub play his tone, and the software does the measure.
but when i want to run the 5 point calibration then it fails.
it detects the sub, it detects the mic and serial of mic, then it launches the tone of the sub, and then it says error 0000x04, impossible to successfully measure the response of the sub.
in the same message it advice to move up the level of the sub, and try again, but even pushing it at full speed, it just doesn't work
anyone had the same issue? any idea?
cheers
