Hi Everyone,
I am in the planning process of building my sub using the above driver. I want tuning between 25 and 28hz. I will be using an SVS PB-13 Ultra to take over the lower end of the spectrum. I am after maximum output above the 28hz range. I will be using 18mm marine grade plywood to build the enclosure. For the ports is PVC pipe fine? or should I use premade flared ports? Is the below graph a concern regarding enough port surface area for the desired tune? What would be the optimal design goal here. Thanks in advance.
Cheers
Cheers
It will just punch you silly.
But one fine day when I am free I shall fix it, so that at least the $$$ is not wasted (can't sell DIY for nuts over here in SG). Trying to earn as much money as possible while the chance/opportunity is still available!
