AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › The Pioneer Elite BDP-09FD Owner's Thread...
The Pioneer Elite BDP-09FD Owner's Thread... - Page 262
post #7831 of 8421
Just to append to people having problems with prior firmware;
I put in Prince of Persia and got these messages "CAN'T PLAY" + "UNKNOWNDISC". I have this problem with firmware 2.70 and just updated to 2.71 and still have the problem. I also unplugged the unit for a few minutes. I'm not going to bother doing a factory reset.
Actually, I've had a few issues with Blockbuster Online rental discs freezing on certain chapters since upgrading to 2.70. I'm leaning towards the disc or firmware as the issue for these problems.
Also, there is a crater on this particular disc. I'm not sure if this is the problem in this situation.
post #7832 of 8421
I've only noticed the "can't play unknown disc" on Season 1 of "Justified", also on that set I did get audio pops that went away if I rewound it. There was also disc freeze that went away if rewound or fast forwarded. I returned the BD to Amazon (I had a problem with "Mad Men" with a freeze that a new set fixed) and the new discs had the same problem. Other than that I have not seen many errors. However I have not been buying many discs lately.
On another note, I've been recovering from spinal surgery and not on the computer much. Now on long term disablility. I do regret missing the $500 BDP=09FDs.. I could use a second one.
I did notice going through some of this thread that the Pioneer-Oppo sniping is still the same..
post #7833 of 8421
Originally Posted by LaoChe View Post
Are you using analog or HDMI?
it happens over multichannel analog out , over coaxial and over HDMI
its not my marantz receiver because i dont get the pops with the Oppo
Not as loud as the DTS bitstreaming bomb but enough to take u out of the film
post #7834 of 8421
Get version 2.71 of the firmware here: http://www.pioneerelectronics.com/ep...DP25A_V271.zip
post #7835 of 8421
i know , it didnt work
post #7836 of 8421
Hi
After just about giving up all hope of sorting my LX-91 out,it finally managed to make its way back to Pioneer,where they changed the drive assembly.
Well shes back in business,better than new,loads faster and after 20 or so discs,has not refused to play any BD's I've thrown at it,including a few titles that originally would not even look at since it was new.BTW I have the Stegen multi zone kit installed which still works perfect.
Now while I had the LX-91 away,I had the OPPO 93 in the system.
I'll start by saying that value for money the OPPO is a great player,what it has over the LX-91 is faster loading times,subtitle shift for CIH,and that's about where it ends,also 3D capable if that's your thing.
It might have 3D picture,but the sound is definitely 2D.Compared to the LX-91 it sounds flat across the front soundstage,there's no width or depth to the sound and it sounds harsh,bright and metallic,especially when pushed to high volume levels.
I found the sound terrible and could not even sit through a full movie sometimes.
In comparison the 91 draws you into the movie,with a huge natural,smooth and dynamic soundstage.
I only run the HDMI cable for DTS-MA and Dolby TrueHD,so apples for apples and yes I did have the OPPO configuired correctly.As a matter of fact I triple checked as the sound was that bad,I thought it was setup wrong.
So at the moment I couldn't be happier that the 91 is back in the system,for how long,who knows.Maybe the OPPO 95 will offer up a better sound,maybe the nu-force mods might improve it somewhat.I should be trying a 95 soon,so we'll see how it compares.
Please note that this post is not intended to flame the OPPO 93,as I said bang for buck it is a good value,but it's not all that.
System in use-Meridian 568.2,Meridian HD 621,2 x Meridian 558's,M&K S-150thx 7.1 system,all cabling is Kimber.Most power cables Shunyata.
Cheer's Steve
post #7837 of 8421
Originally Posted by williamtassone View Post
anyone else noticed "pop" noises watching Bridge On The RIver Kwai. 2.71 FW hasnt fixed it
yes
post #7838 of 8421
This wasn't you reporting the issue, was it?
I don't have the movie, so I can't verify that for you.
post #7839 of 8421
Originally Posted by stevethx View Post
Hi
Cheer's Steve
I wish I caught the 09FD $500 sale. I could of used a backup unit. It is going to be a sad day when my 09FD goes out and it can't be repaired.
post #7840 of 8421
Last night I put in a DVD with 2 avi files and 2 divx files on it. It will not play on the BDP-09. I even tried trough the home media menu. Still no go. What am I doing wrong?
Dave
post #7841 of 8421
Well...false alarm. I returned the disc to Blockbuster and they could not play the disc either. I got an exchange for the same title and the second disc worked.
post #7842 of 8421
My Elite player is in service for one month and customer service has no clue when it will be ready.The only problem was that I was not sure about digital spdif output and I wanted technician to check it out.I do not think that Pioneer is doing good job with support!
post #7843 of 8421
I've had my VSX-59TXi receiver in the shop since the middle of June 2010, the delivery of one of the power boards keeps on getting pushed back.......
Not trying to scare you..... I had my cat vomit on it while I was not home and it blew out two power supply boards.
Fred
post #7844 of 8421
Blu-ray or DVD?
post #7845 of 8421
Originally Posted by prepress View Post
Blu-ray or DVD?
I'm sure he means the BD. It popped on me with the BDP-09 and SC-09 AVR. I even changed from bitstream to having the 09 player decode to PCM, didn't stop the random pops. It's something involving how Pioneer decodes DTS-MA not compatible with how the BD is mastered.
And Bridge is the only BD I've played so far with this problem out of hundreds I own.
post #7846 of 8421
Same pop on the 51
post #7847 of 8421
Have you tried it on another brand BD player? Wondering if this problem is isolated to just Pioneer players.
post #7848 of 8421
yes its the BLU RAY version of bridge on the river kwai thats causing "pops"
people on the UK forum have noted this with their version of the BDP-09
this film plays perfectly with my oppo . Ive emailed Pioneer USA technical dept and when theyve finished clipping their nails, they'll look into it
I guess blown tweeters are not high on their list of priorities so Just in case ive never used bitstream , just PCM
post #7849 of 8421
What in the world ever possessed you to instruct your cat to do that?
post #7850 of 8421
How is this player compared to other players in the same class?
Will pioneer introduce a new flagship blu-ray player soon? This one has been out for some years now and i dont know if it can still keep up with the newer players.
I want to upgrade my lx70 and i dont know if its smart to get this lx91 or wait for a newer model.
Ive tried the denon 4010 but i dont like the sound. Pioneer has more clear sound in my opinion.
post #7851 of 8421
As posted previously, I have both an 09 and the Oppo 83. Well, the Oppo has decided to misbehave and was sent off for repair yesterday. For BD, my only option for now is the 09. The 83 was a direct connect to the TV (a Kuro 111FD) for "quickie" viewing, when I didn't feel like firing up my whole system. Now, since the 09 has two HDMI outputs, I should be able to configure the second one to output both audio and video to the TV. I'm curious to know if anyone else (especially anyone with a Kuro) is doing this.
post #7852 of 8421
This player is still the best player overall made to date, of course unless you are concerned about having the fastest load times. As far as Pioneer introducing a new flagship player, who knows! If they do release one it most likely will be the Pioneer/Sharp junk that they are building now. I for one would be ecstatic if they released a 09/91 replacement that was once again purely Pioneer only, but I would not hold your breath for something anytime soon. The hope from us loyal Pioneer fans is that Pioneer finally sees the light and starts building their own players and not these players built with Sharp. This is the reason that I refuse to replace my Elite HD1 from 4 1/2 years ago, nothing wrong with it and nothing out there that will beat it in regards to overall playback and performance!
post #7853 of 8421
Thanks for your reply.
I thought this would be one of the best and i dont care much about loading times.
Im just looking for the best player that can play the HD audio. My lx70 is just too old despite it still awsome!
I have a B&W 802D,htm2,scms surround, db-1 sub, classe ca-5200 and ssp-800
post #7854 of 8421
Not if you are HDMI for audio and video! Then look elsewhere.
Lossless bitstream over HDMI and 1080P24 video over HDMI, the best way to have audio and video today, is not 'enhanced' by this player (or any other for that matter). If using HDMI, this player is in the middle of the pack (as well as slow). Moreover, Pioneer does not have the greatest track record for players that play all discs...
If you have a 1080i set and / or are using the players 7.1 analog outs, then, yes, it is a very good player. Analog is this players only strength - all else, it is far behind the times (but 2 HDMI outs are convenient in some theaters.
post #7855 of 8421
You are so freakin' annoying. Funny how you don't go parroting this crap on the Ayre DX-5 thread. They make all kind of outlandish claims yet you don't seem to chime in regularly there with your "HDMI is all the same" comment. And this is a player 5x more expensive than Pioneer's 09FD. Weird. Maybe you have some kind of agenda?
Instead of worrying about this thread, you should spend more time in the Oppo 95 thread. They seems to be having quite a few issues with their $1000 BD player. You may want to throw in the your 'ol "any player over $500 is a waste" comment. You may also want to throw in your 'ol "players shouldn't need firmware update to play BDs" comment for good measure. I'm sure they'll appreciate those helpful and informative posts from you.
Sure it is...Sure it is...
For the new members that don't know "thebland," he does not own this player.
post #7856 of 8421
For the new member that don't now "thebland," he does not own this player.
Since when does owning a player make one an authority on the technology? Cognitive dissonance at its best as there are far better and more reliable players for far less money. I have experience with this player and spent much time with Chris Walker (Pioneer) with this player (at CEDIA years back at it's introduction). This player was introduced at a time when there were many hold outs from HDMI. The analog stage on this player is first class... just like the Ayre.
But if you are HDMI, the many no play discs, the many firmware updates, drive failures and the fact that bitstreamed (packed) lossless audio is identical in all players with HDMI as well as a 1080P24 video signal, then you have very little need for this old player.
Tell me exactly how the audio and video is better through HDMI on your player? Be objective, not subjective (e.g is sounds more open, etc and that sort of garbage).
post #7857 of 8421
......you should spend more time in the Oppo 95 thread. They seems to be having quite a few issues with their $1000 BD player.
LaoChe,
I was considering this player and I have read every post from that thread. At least I thought I did. What other issues outside of a few minor streaming or minor user created media issues that have for the most part been resolved? I am not trying to be confrontational, but I may need to reread some of the postings depending on your comments before I part with $1,000. I'll admit that I may have glossed over some of those minor issues since they wouldn't affect my usage of the player.
Thanks for anything you can offer.
Respectfully,
Willie
post #7858 of 8421
Based upon this and my previous post I have an idea, though I'm not sure I'll actually do it. It may be interesting to configure the 09's second HDMI to output audio and video and compare it with the Oppo 83 when it comes back from repair. This has nothing to do with resolving the "bits is bits" debate but with my own curiosity, assuming it becomes strong enough to actually make the time for a comparison. And though this will be going through my Kuro's sound system (very good for a TV) and not a full-blown HT system, maybe there will be something noticeably different, maybe not. Normally I'm not that interested in such things and don't have the time. But who knows?
post #7859 of 8421
It wouldn't mean much to others if you did. It would be system dependent. Likely both will look excellent.
^^^I have 3 Blu Ray players in the rack with a reference SIM2 Lumis HOST projector and ISCO anamorphocs. They all look great..108024 is a good thing. With the advent of HDMI and no need for scaling (if you have 1080P monitor), reliability and features have superseded PQ variances between players. Those were the analog days. Today we simply lift the native res off the disc and pipe it directly to the monitor. All players do it well. the 09 is a decent player if msrp was in the $400 range. It is easily bested by newer, faster players. ^^^
Technology moves fast... So, it's really no surprise (I too have $2000 into my old Denon 3800 - it was the best thing for a year or so but like the 09, it is bottom of the heap relative to the newer $500 - $1000 players.
post #7860 of 8421
Jeff,
Unfortunately, some don't want to see their expensive purchase of yester years eclipsed or devalued by cheaper ($) and better. I've accepted this inevitability and evolution of technology. It's what makes this hobby so great. I know a lot of people hyperventilate at the mere mention of the name Oppo (lol). I briefly owned a Denon DVD-3800BDCI and returned it because it wasn't an improvement over my Oppo BDP-83SE in my setup. I still own the Oppo in addition to two Pioneer BDP-320s and a Sony BDP-S5000ES, but the Oppo is my player of choice, because of intangibles that go beyond blu-ray and DVD playback. This is what worked for me in my setup.
The BDP-09FD is a great player based on the consensus of this thread, but it along with the Denon DVD-3800BDCI and the Oppo BDP-83 are all outdated (technology and ergonomics) by the current transports of their brand (except Pioneer). The bottom line is that there is cheaper ($) and better available, but I have no regrets of any of my purchases regardless of their price at the time.
Willie
