I need help with my Toshiba Recorder. It is quite anyoying when my recorder is idle for awhile it will alert you that if you want to keep watching tv hit the cancel button or the recorder will shut off. I use my recorder for sound so at times it will be idle at hour at end but I want it to stay on. It will shut itself down does anyone know how to keep from turn it self off is there a setting I can go to? I know it a power saver I quess but I want my recorder to stay on until I turn it off. Does anyone else have this problem?
Kevin
Kevin
