Why? I never heard that?
thx
bob
If you like more "detail" than what MCACC gives you, by all means turn the sub down. If you want it flat, take what MCACC gives you.
All you are left with is a basic graphic EQ which provides no room correction and will not address issues in the time domain. Why is that you ask? Because you must switch from Audyssey mode to Manual mode to make ANY EQ adjustment. Suddenly, hundreds of time domain Audyssey correction filters lost!
And as if that wasn't bad enough, you cannot configure more than one custom EQ preset, so if you want to change it, you have to go into setup, and change it manually for each and every channel/speaker.
Again, you will lose all Audyssey capabilities and will not have Audyssey Dynamic EQ and Audyssey Dynamic Volume capabilities by making any changes to the EQ. OK, so you decide you will leave Audyssey EQ set rather than making your preferred EQ tweak, because you want the Audyssey room & speaker calibration, Dynamic EQ, and Dynamic Volume capabilities, and you decide you will just use bass/treble controls to adjust the tone to your preference. Another big problem here. Not only does this limit your tweaking to a couple broad frequency ranges, but if you are using Audyssey Dynamic EQ, you can NOT adjust the tone controls either!
You will run into the same limitations on other receivers with Audyssey outside of high end stuff using the expensive Audyssey Pro kit and license, which still doesn't make it quick and easy to tweak your EQ curves. Audyssey doesn't want you to be able to tweak the EQ/tone to the content, your hearing, or your tastes.
Unlike Audyssey equipped systems, you still retain your full MCACC calibration & room correction in the time domain. You do not lose functionality of the DRC (Dynamic Range Compression), mightnight, dialogue enhancement, Auto Level Control, THX Loudness Plus, or what have you. Of course, you still have phase control, standing wave control, bass management, etc as well. And from what I understand, the tone controls are still available, although manually tweaking the EQ is much more precise anyway. So if you like to control or tweak your sound, even if just a little bit, in addition to the automatic room & speaker calibration, environmental acoustic correction in the time domain, and without losing other functionality on your receiver, you are much better off with Pioneer and MCACC. Pioneer VSX-1018 and all of the current Elite models are the only ones that handle this the way the tweakers prefer and lets you have the "final" word on how it sounds after all the auto room EQ & calibration has run. Now, finally a match made in heaven.
