I have the 1222 which has 2 sub outs for the primary zone. It also has another sub out for zone 2. Makes sure you have it in the right one. Lastly while you ate unplugging then usually if you touch the 2 contacts on the rca cable you will hear output from the sub. If this works than that should eliminate the cable and sub as the problem.Originally Posted by Ace2377
Yes, the sub definitely works. It worked with a previous receiver, and also worked with a 1522 running MCACC. The first one I bought I could not get the HDMI out 1 to show a display on my screen, only HDMI out 2 would work. I ran MCACC on that yesterday and it worked perfectly fine. I took that receiver back last night and exchanged it for another 1522. I have the HDMI out 1 working now, but when I run MCACC it does not detect the sub. So it worked fine last night with MCACC, but does not now. I can't think of anything I did differently. I am so beyond frustrated with this thing!
To make matters even more confusing, after failing last night to get this run correctly, I tried it again first thing this morning without the mic in the correct spot just for "fun." It ran through and it actually detected the sub. I had to stop it though because I didn't have everything positioned right and still had windows and doors opened. So about a half hour later I have the mic and room settings right and ran it again. This time, and every time since, it has not detected the sub.
you could easily have an developed an intermittent short or faulty connector on a cable from being angled down in a tight corner, etc.
