I don't have a 1019, so it may be different than what I'm used to, wherein the LCDs on front panel display the current input signal. However, the 1019 does have little indicator lights, one of which (center top of display) lights when a PCM signal is being received. That is the only one you can expect to light, as the receiver only "sees" PCM with your arrangement. The decoding is being done by your computer, and the receiver has no way of "knowing" what the signal was before the computer decoded it into PCM. If the front panel LCDs did spell out the input, all they would say in this case would be "PCM." It can only display the original codecs if it receives a bitstream which it can decode itself.
I believe the connection to your TV the manual refers to is not relevant to you. Connection from the AVR to the TV will not affect the AVR's ability to produce sound (although there is a setting that allows you to bypass the amp and use the TV's speakers).
As long as the sound is as good as you say, I wouldn't worry about any of this.
