AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Mounting Brackets Question for Panny Plasma
post #1 of 2
Hello Everyone
2 Questions...
I just mounted my first Panny 50-850U and everything turned out nice and leveled. The only thing is I wish it was a bit higher. The mounting brackets that attaches to the TV itself has holes where you can make the brackets higher and lower. As of now they are installed centered to the back of the TV, would it be bad if I put the brackets lower which would make the TV a little higher?
We just got new furniture which now makes the TV not centered. All I would have to do is drill 2 more holes to the right stud and re-mount it, which will make it centered. If I were to do this, 2 lag bolts would have to be removed and screwed back in the same hole but just in a different place on the mount. Would this make the hold not as strong?
Thank you for any feedback
post #2 of 2
You should be OK on both counts. The majority of the force on a mount is downward rather than outward.
