AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Linux Chat › MythTV Audio Problem
post #1 of 4
Hello,
I have just finished building a MythTv box and am overall happy with the progress. I am fairly experienced with Linux,
but more on the command line and programming levels. I first tried to use Fedora 10 with the MythTv software set up by hand. After encountering numerous problems I
switched to the newest version of Mythbuntu. This fixed almost all
of my problems, except one, I can hear the TV audio even when not in "Watch TV".
My system is using a pcHDTV HD-5500 combination NTSC/ATSC/QAM tuner card. I have analog
cable and am only using the analog tuner currently. To get audio when in analog mode a pigtail is connected from the card to
the line-in on the motherboard. I then have the speaker-out connected to the
TV. The problem is that I can hear the audio of whatever
channel I was watching (or static if the card is not tuned to a channel)
even when MythTv is in the main menu (i.e. not recording or watching live TV). Has anyone else encountered this problem before?
post #2 of 4
The master guru's here, please correct me if I am wrong:
I do not believe you need the jumper from your tuner card to the sound card. I do not use one in my setup although I do not have the same tuner card as you.
post #3 of 4
The documentation that came with the card says that the pigtail
is required when using the analog tuner. I also tried to unplug it
and couldn't get any audio with it unplugged.
I'm thinking it is an OS problem. When I was working with
Fedora 10, I couldn't get MythTv to work but was able to use
tvtime to test the card. The audio worked correctly then. I
have not changed any hardware connections, just installed
a different OS.
post #4 of 4
I was able to solve the problem. The card apparently does put
analog audio out without the pigtail. This is not mentioned in
the instructions however . I will still try to experiment because
the audio does not sound as good as with the pigtail.
Thank you.
  Back to Forum: HTPC - Linux Chat
