AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › converter boxes
converter boxes
post #1 of 2
I am planning on ordering two digital converter boxes and wanted to know which boxes (if any) perform well to receive any of the weaker signals in my area.
I went to tvfool.com and there are quite a few channels I would like to get but is highlighted in gray and is within 82 - 109 miles of my location. Is there a possibility that any CECB receivers can pull in these weal signals with the right antenna or am I out of luck with these channels?
I've narrowed it down to Zenith, Channel master, and DTVPal/Plus. Are these 3 good for picking up those signals or are there others that are better?
Any help will be appreciated.
post #2 of 2
Condor1,
1: When creating a thread- USE A DESCRIPTIVE THREAD TITLE...
It helps others later on (with the same problem /concerns) and increases the responses to your problem.
" Converter boxes" gives little cue to what your concerns are.
2: Here's a thread about which box is best for fringe areas that may help:
Help!! What box to choose for fringe???????
http://www.avsforum.com/avs-vb/showthread.php?t=1113044
PS: You may want to check out the threads on what kind of antenna setup you will need...
