I'm in the market of a new display. I'm replacing a 10 YO 60" Toshiba tube rear projector. In my situation size matters. My viewing position is 15-ish feet back from the screen. So to keep around the same screen area, and get some benefit from HD, If figure I need at least a 60" screen.
I've been going around in circles for years on this. I'm close to settling on the Samsung PN63A650.
I've considered and dismissed a number of other alternatives:
58" Panasonic (to small)
67" Samsung LED DLP (Geometry issues, uneven brightness across the screen, narrow viewing angle)
All other DLPs (light bulb, color wheel).
Varions 65" panels - Panasonic Plasma, Sharp LCD (too expensive).
Pioneer 60" Kuros (too expensive)
This left me with the 63" Samsung and the LG 60PG60. The sammy being a little bit bigger gives it the advantage.
Now reading some of the reviews of the 63" Samsungs (more the A760 - I haven't found a good professional review of the A650, and they seem like the same basic panel), it seems like the reviewers felt the Samsungs were weaker than some of the other panels, especially in black level, grey scale, and maybe color accuracy. Some of this is priced in. I knew the Kuros had better black level than anyone, and I give the Panny some points over the Samsung on picture quality.
But in reality, not having the panels side by side, is any of this going to make much of a difference. Given that I've been living for years with and aging SD projector with visible geometry and convergence problems, anything I'm going to get is going to be a quantum leap. Any of the other choices have their own tradeoffs (price, size, other PQ issues.) Should I keep going in circles waiting for the perfect panel that may or may not every hit the market, or should I just buy the damn Samsung. Is there anything on the horizon (say three months or so), I should wait for?
Moneywize, I figure I can get the Samsung for <$3500. Any other choices would need to be in that price range also.
and do not look back
