So I just purchased a new samsung 550 1080 lcd and for the most part it has been working fine. One issue though and I'm not exactly sure what it might be. Occasionally when I turn the TV on there is no sound coming through. I tried playing with the settings the first time it happened but it seems that the only thing that works is when I unplug the HDMI cable for a moment and then put it back in. So is this a cable connection issue in which I should contact my provider or should I replace the HDMI cable? any suggestions
thanks
thanks
