Soffit bass traps - Page 2
post #31 of 41
bump
post #32 of 41
Originally Posted by 68sting View Post
I have a platform thats half the width of my room and I was hoping to turn it in to a bass trap. After reading your comments above I'm wondering how it will impact its effectiveness being only half the room size. Also all I need to do is add a couple registers in the rear floor area to turn in to a bass trap? That sounds too easy. Thanks in advance
I have the same situation and was wondering the same thing
post #33 of 41
For a platform to be used as an effective bass trap it must be to both side walls and the rear wall.
post #34 of 41
thanks for the reply Dennis, appreciate it.
post #35 of 41
Im kind of newbie to all of this so please forgive my rookie question but how did you get such a clean edge on your vertical GOM fabric covers on your soffit? does anyone know of a link that shows all the installation tricks of using GOM.
post #36 of 41
Why is that?
Also, what is the relationship between the floor register opening and the frequencies damped? Is a single 10"x4" register sufficient for most bass frequencies or would a 8"x2' register work significantly better?
post #37 of 41
If the platform extends the width of the room and goes to the rear wall, the platform is positioned to be within the areas where modal frequencies are peaking (low velocity/high pressure). With proper design of the seating platform, 4x24, 4x36 floor registers (bar diffusors) can be used. By properly designed I mean the following has been accounted for in the construction of the platform:
1. Fiberglass insulation has been installed in the cavities of the platform;
2. The areas (very near the wall) under the platform have been framed with sufficient volume to do some good.
post #38 of 41
Dennis I am taking your advice and building my platform wall to wall and all the way to the back wall.
I will have enough opening along the back and was thinking about putting registers along the side walls as well. Do you think that this would be a benefit to the room?
post #39 of 41
I was also thinking about opening the front of the platform as well if this would help.
post #40 of 41
Not trying to hijack this thread, but I'd like to know how I could put some leftover R19 unfaced pink insulation bats to good use as bass traps. I have 2' of depth behind my screen wall, so size and looks aren't necessarily an issue. If I did something floor to ceiling in both corners, I would have 4 tri-corners trapped. My room dimensions are roughly 19'x14.5'x8'. If I left the insulation in it's plastic bag (about 20" in diam, 4' tall) and positioned in the corner, would it effectively trap bass ?
Bill
post #41 of 41
Bill
That's exactly what I did in my theater, which was based off of one of the audio experts recommendation (can't remember which one at the moment).
CJ
