Originally Posted by
JetJockey1
Try to google PLV-Z5 (very similar model)thermal reset fix, unplug unit, its 6 screws, remove cover, push the reset button, replace cover....good luck!
Thanks, that's good to know.
I talked with someone at the Sanyo Chatsworth repair facility this morning.
Since the the unit has <200 hours I'm going to give it to them for a look see. The unit was pretty noisy anyway.................. ~45+db when running in eco mode so it needed some attention anyway. This will be a good test of Sanyo's service. I was planning on upgrading to the new 1080P projector.............. before this issue with my current project.
thanks again for the reset switch suggestion
JohnG
