Hello All,
I have a UTV with a 120GB HD which has begun to have HD problems.
The HD is not completely dead and would like to clone the contents over to a new drive before it completely dies.
I've read the FAQ and searched the forums but am still a little confused. It sounds like it is possible to clone a drive, but the steps to do so are not clear. It also seems like I can clone the 120GB drive to a larger 160GB, however the extra 40GBs will be lost.
Can someone confirm it is possible clone an existing UTV HD (with recorded programs and all), to another drive?
From what I've gathered thus far, I believe these are the steps:
- Power up the UTV with the existing marginal drive.
- Boot PC and pause before drives are detected
- Hot swap IDE cable from UTV to PC (leaving power uninterrupted)
- Continue to boot PC
- Use WinHEX to copy/clone the existing drive to the new.
I need clarification from this point. I would like to avoid paying for WinHEX since I don't have much use for it after the fact. I've read the 30 day trial of FlexHEX works, can anybody confirm this?
Do I need to worry about reference points and such for a full drive copy/clone? I suspect this is only for upgrading or pre-loading a blank drive with a fresh image?
I would appreciate if anybody can give a step by step for either WinHEX or FlexHEX. Is it at simple as selecting the physical disk and copying/pasting to the new physical disk?
One last clarification. Once the contents from one drive are copied to the new, do I simply install the new drive in UTV? Won't the unit try to ZERO out the drive, lock it and dial out for the current image? Or will the unit simply detect the existing (copied) image and lock the drive?
Thanks in advance for any assistance/information anybody can provide.
Gavin
Gavin
