AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › poly batting for top half of sides/rear theater
post #1 of 4
I was wondering what the best weight / loft of the poly batting for the top half of the theatre wall sides should be. I can never seem to find anything very heavy on Joanne's fabrics. I did find the following batting though
http://www.batt-mart.com/site/490194...C-RS-2096-ROLL
Does this look like a good choice? 20oz/yrd and 1" loft...
post #2 of 4
Use highest ounce from Jo-Ann, then double it on the wall. That will get you approx 1in that's in line with the Linacoustic.
BTW, they always have those 40% off coupons!
post #3 of 4
This is what I find at Joanne's:
http://www.joann.com/joann/catalog.j...RODID=prd14621
Is this the item you are talking about?
post #4 of 4
I used the 1" loft on my upper wall and that worked well
