Naah, anyone can run their own website, with the amount of posts you have accumulated here you could probably fill half of wikipedia...
Originally Posted by Rgb
While the missing HDMI is not an issue for me (trivial to get a DVI to HDMI adapter or cable), it's unbelievable they would omit an SPDIF out on the back panel.
However, if you zoom in on the Zotac board pic at newegg, there is an SPDIF header on the lower right- trivial to add a coax out.
I mentioned HDMI because that's another way to get digital audio, I know a DVI to HDMI adapter for video is trivial, there is even one included.
However the SPDIF header is a valid option, but not suited for someone inexperienced as tracking down the right back panel adapter or making your own is not trivial unless you know what you are doing (I'm sure YOU do!)
