AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › bright spot on screen. Is this projector issue or screen?
post #1 of 5
I have 130" screen. The bright spot is visible but not on the same place for all the people.
Is this screen issue?
post #2 of 5
The screen.
post #3 of 5
thanks for quick reply? Any way to fix this?
post #4 of 5
You really haven't submitted enough information about your projector, screen and location of each. Usually, hotspotting is caused by less than ideal projector location, i.e., height of projector with respects to the screen. Is the projector directly in front of the screen, above or below the screen? Other times the projector may be incorrectly improperly calibrated.
post #5 of 5
Rich is correct, much more info is needed before offering much advice. The short answer is the screen, but there are other considerations, as he pointed out.
