AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › audio question..
audio question..
post #1 of 11
I recently got a 1080p LCD tv. I am currently using components with optical audio. When I transfer over to HDMI does it bring audio as well?? I don't have HDMI into my receiver so the only way I can bring audio is thru digital coax or optical. Is there anyway I can run HDMI with optical audio??
post #2 of 11
The HDMI from the Xbox will carry both audio and video to the TV. You can buy a dongle box for the X360 to allow you to use the optical output to your receiver and run your HDMI for the video.
post #3 of 11
great, thanks!
I can use my current dongle with components the only thing is I need to take the bottom half of it off to get at the hdmi port! I tried using a knife to pry it apart but no luck.. seems like its snapped together
nm got it working, its a tight fit but works
post #4 of 11
When playing games does any sound come thru the center channel???
post #5 of 11
It should, quite a few people find that when using HDMI to the reciver they have problems with sound. Try andf check on your reciver if there any lights/menus/displays that let you know your still getting a DD 5.1 signal and not PCM 2.0 signal.
I've resorted to HDMI for picture and Optical found sound as it always works.
post #6 of 11
If you're having audio issues with HDMI, go to your sound options on the dash, set to 2-channel, then set back to 5.1. That usually will fix any of the common handshake issues with the 360.
post #7 of 11
It varies from game to game - many games don't utilize the center channel.
post #8 of 11
i thought a developer requirement for the 360 was DD5.1?
post #9 of 11
Every game i've played on the 360 so far has DD5.1, i've yet to see a game without it.
post #10 of 11
The 360 encodes core game audio into a Dolby Digital 5.1 stream by design. A developer can optimize their game audio code for 5.1 streaming in the Xaudio API during development of a title but there is no actual Dolby Digital work in a game except for the occasional cutscene or video clip that has a pre-encoded track. The only requirement is that the game be compatible with the DICE (Dolby Interactive Content Encoding) technology built into the console.
post #11 of 11
Thanks for all the info.. I actually had a rca/optical dongle that came with my elite that I forgot about. I got the center channel working, I had to go thru a setup on my receiver and select how many speakers I had and that did the trick.
  Back to Forum: Xbox Area
