Amazon has these on preorder for $210.
http://www.amazon.com/gp/product/B00...pf_rd_i=507846
Here is info from BIC America website
BIC F12
Price (MSRP): $449/Each
Design: Front-firing 12" 475-watt peak powered subwoofer
Frequency Response: 25Hz - 200Hz
Sensitivity: 90dB
Drivers: 12" Injection molded woofer with heavy duty surround
Magnetic Shielding: YES
Gold-Plated Terminals:YES
Recommended Power: Built-in Amplifier Power: 475 watts Dynamic Peak, 150 watts RMS continuous
Impedance: 8 ohms
Dimensions: 17"H x 14 3/4"W x 17 1/4"D
Weight: 42 Pounds Each
Warranty: 5 Years Parts & Labor
Compared to Acoustech H-100
Price (MSRP): $499 / Each
Design: Heavy Duty Front-Firing 12" Powered Subwoofer, BASH designed amp.
Frequency Response: 24Hz - 200Hz (+/- 3dB) variable (adjustable crossover)
Sensitivity: 90 dB
Drivers: Heavy Duty 12" Long-Throw Poly-graphite woofer with high power magnet.
Magnetic Shielding: NO
Recommended Power: Built-in Amplifier Power - 150 Watt RMS, 500-Watt Dynamic Peak
Impedance: 8 ohms
Dimensions: 17" H x 15" W x 18 1/4" D
Weight: 42 lbs Each
Warranty: 2 Year Parts and Labor.
It seems that they are almost identical but H100 is slightly better in the specs
BIC F12
Sensitivity: 90dB
Impedance: 8 ohms
Sensitivity: 90 dB
Impedance: 8 ohms
Weight: 42 lbs Each
