AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › BIC America F12 sub anyone ?
BIC America F12 sub anyone ? - Page 51
post #1501 of 2724
Originally Posted by Sound Master BIC View Post
Geez Jim, I would think a guy with your experience would be able to teach me how to calibrate, member since 04 and 4,000 + posts. You're already further ahead than me, I don't have a meter or a calibration disc. I think you'll find you can plug it in, you must already have a spot for it, run your receivers calibration and then just tweaks. Don't mean to sound dickish Jim but I think sometimes people get a little carried away with setting these up, it's not that difficult. JMHO, no offence to anyone.
Geez Sound Master BIC, I'm sorry my question bothered you. Why would you ASSume my receiver has Auto calibration? I thought there may be some tip for this particular sub.
post #1502 of 2724
Just curious and no offense but how does a 'senior member' with more than 200 posts not know about AVR's and LFE and subs? .
I wonder how many posts before one becomes a know it all?
post #1503 of 2724
The documentation that comes with the F12 is probably the most comprehensive that I've ever seen come with any sub. Depending on which setup option you use just set the switch to either DD5/6/7.1 for coax or "DolbyII" for L+R speaker wiring. For DD the xover is bypassed but most turn it all the way up anyway. The volume usually works best between 2 and 3. This sub is more sensitive than many others and needs to be set unusually low and work your way up form there. Also I found the rear port needs to be about a foot away from a back wall. Propping a pillow behind it seem to help reduce some of the boominess. Good luck with your new toy!
post #1504 of 2724
Thanks RobLee. If I set the sub's decibel level with my receiver, I still set volume on sub to 2 or 3?
post #1505 of 2724
Set your AVR sub level to 0db and start by setting the sub's knob to around 9 o'clock. Do your calibration or listening test, adjusting your speaker levels on the AVR. If the sub level is within bounds of the other speakers (most feel +/-10db is workable) then leave the sub set. If it is drastically different from the other speaker settings then set it back to 0 and adjust the sub's knob slightly. As I mentioned earlier, many find this sub's volume knob to be overly sensitive and most find that 9-10 o'clock is usually about right. Of course, it can end up anywhere from near min to near max depending on the sensitivity of your other components.
Correction: "set it back to 0 and adjust the sub's knob slightly" THEN START OVER AGAIN.
post #1506 of 2724
While I don't always want to produce a live rock concert in my living room, now and then I do like to crank it, especially with things like the new Blu-rays from RUSH, U2's 360 and other bands whose music is normally best when fairly loud. At the same time I like it clear, fortunately my system, 4 good-sized towers, a 135 wpc Yami and of course the F12, it is both loud and clear.
My music collection, while quite extensive, has nothing in it that has bass cello or tympani so I can't say how those things sound, maybe I'll get something and try it out.
Those that know RUSH know they are not a thumping bass type band but Geddy's bass plucking was clear and concise while Neil's kicks were solid and clear along with the bigger Toms. If you're a RUSH fan Beyond the Lighted Stage is a must have!
Got the dvd off e-bat 13 bucks. Sounds like a good investment
post #1507 of 2724
post #1508 of 2724
Sorry you took it that way, it was sort of tongue in cheek, not serious, didn't 'bother me,' at all. The ASSume may have been uncalled for though!
I always figure when I see someone with so many posts they must be pretty knowledgeable, that's all. I also figured, almost all semi modern receivers have some sort of auto calibration, my OLD Sony even had it.
post #1509 of 2724
Round about 467 I guess...
post #1510 of 2724
I just received my F12 from Amazon. I opened up box and found that 2 of the 4 cover's pegs were broken off in the sub. Has this happened to anyone else? If so, did you have to send the whole sub back or just the cover? Thanks.
post #1511 of 2724
IF it's like Amazon's standard damaged item return process you can file for a replacement immediately and they will overnight a replacement to you. They will give you 30 days to return the original (at their expense) or they will charge you for it.
You will have to file a claim with photos of the damage but a replacement should be within one or two days I believe.
post #1512 of 2724
Hi
I just bought f12 and hooked up with my pioneer 1020 k using LFE out and Set receiver type to 5.1 in sub and set crossover freq to 80 hz in receiver.
With this setup I get good bass with this setup when source is playing in 5.1.
When I play in stereo mode, I am not getting bass in sub. So I guess it is playing in 2.0
So what I did is
i. Connected left and right wires from receiver to sub and connected output from sub to left and right speakers
ii. Then set receiver type to prologic in Sub
ii. Set crossover to 80 hz in Sub
My question is will this setup be alright for all modes to pick up bass below 80 hz?
post #1513 of 2724
Originally Posted by arul_nandha View Post
Hi
So what I did is
In 'Stereo' mode only sound is sent to the Front left and right speakers
An easier way to get back to the original set up and to get bass in stereo mode is the select 'Plus' in the receiver
post #1514 of 2724
If you've nevered had a powered sub before and are thinking of getting one. Get TWO at the price these are at. You will not be disappointed I posted some pics of my system earlier,so you now I'm not kidding. A couple pics on post 48 Hey why would I Lie about a thing like that.
post #1515 of 2724
Guess I shoulda listened (already have one and am looking to purchase a second).
Looks like Amazon's price has jumped up to $260, argh.
Where is the new cheap place to get one, guys? It looks like Beach Audio is out and the cheapest place I could find one is from Provantage, but that is where I got my last one and they shipping it so poorly, the front grill was slightly broken. Anyone?
On the other hand, what about getting this instead from beach audio:
http://www.beachaudio.com/Bic-Americ...-p-424773.html
Bic Rtr Rtr-12s 12" 200-watt Rtr Series Front-firing Subwoofer (rtr12s)
Less than $175 shipped and it looks to have slightly better specs (higher wattage, deeper Hz range?). What do you all think?
post #1516 of 2724
Anyone think this sub or even the Acoustech H-100 would work well in my situation. HK receiver with Klipsch Quintet III speakers for 100% home theater, no music. I am more concerned with the bass not bleeding into the voices than just raw thump power. Which BIC subwoofer would work best for my small 10' x 10' x 8' (ceilings) TV room??? I can't really see spending a lot more money for what I've spent on the other speakers and receiver for such as small room.
Robert
post #1517 of 2724
post #1518 of 2724
Robert
This would be MORE than enough for your small space. Did you read any of the past pages?
post #1519 of 2724
I don't know Posh, did you read any reviews on that RED rtr? From what I've read, sub matching is critical, even more so that the other speakers in a system... If I remember the numbers correct, the F12 goes down to 25hz-200hz, the rtr says 30hz-180hz, certainly not a match! Then add a side firing port as apposed to rear firing on the F12...
post #1520 of 2724
I had forgotten about good ole BLT, which I had seen mentioned here before. Order placed. Should ship in early Dec I guess.
I can't wait to test out my new receiver's (Denon 4311ci) reported ability to EQ two subs... :-)
Thanks again.
post #1521 of 2724
Do any of the F12 resellers ship to Canada?
Amazon doesn't seem to for warranty reasons.
post #1522 of 2724
Just ordered mine today from parts-express for $215 minus $5 promotional code SAVE52010 so it came to $210 with free shipping. Got it to replace the Dayton SUB-120 I been using and I have ordered a lot from parts-express and their customer service is top notch in my book for anyone who doesn't want to wait and willing to pay an extra $30 over BLT price. Was worth it to me and I got to use BillMeLater so you don't pay upfront.
post #1523 of 2724
Based on this thread I made the jump and picked the thing up for $210 shipped on Parts Express. It will be replacing my old Sony SA-WM20 (8in, 50-watt unit) sub woofer. I bought the Sony sub when I was 16 and even then really only planned the thing to fill in for a year or so until I could replace it with something better. Turns out that while everything else got upgraded, that little Sony sub just sat there at the top of my list of things to upgrade. Living in a house now and having my sub in the living room and not my bedroom made this a good time for an upgrade! I'm looking forward to getting this thing hooked up, and am crossing my fingers that there is going to be a pretty big difference.
post #1524 of 2724
As a follow-up, after talking to BIC, they told me they'd send me a new grille. I get the new grille, and it won't fit. The pegs on grille are much thinner than the original, so the grille just falls right off sub. I call BIC again, and they tell me the thicker grilles are not available anymore, and to send the sub back to Amazon. My replacement should be here Wed. What a PITA.
post #1525 of 2724
What was your process to return it? Is Amazon sending you a new one before you send the broken one out?
post #1526 of 2724
I got the new one today, and everything looks good. I'll fire it up tonight.
I went thru the return process online because I could not find a phone # anywhere on Amazon's website. They sent out a replacement right away, and they give you 30 days to return the original. If they don't receive the sub within 30 days, they bill your credit card. They sent me an E-mail the same day with a pre-paid UPS shipping label to print out. Very simple.
post #1527 of 2724
I've always been very pleased with Amazon's quick and easy return policy.
post #1528 of 2724
post 3
post #1529 of 2724
http://www.techdepotcanada.com/servl...America/Detail
http://www.techdepotcanada.com/servl...PEAKERS/Detail
Does anyone know how these 2 would compare? Is it worth spending the 30 extra bucks for the F12. It's pretty slim pickings here in Canada when it comes to subs
post #1530 of 2724
The first link you posted is the F12 and at $290 that's not too bad. If you figure in delivery and possible cross border fees and duty and taxes that might be charged if it's delivered from the US that could easily be $90 or more. I don't know if TechDepot will add any fee's or not, never ordered from them. If you're in the GTA you could pick it up.
