Saga of the "Old Vic" - Page 39
post #1141 of 1144
Moggie - On your lighted frames, when viewed from the side, can you see the aluminum portion of the Spotlight frame? When I laid the Spotlight frame on my backer box it seemed to stick out like a sore thumb and will probably be worse once everything is painted black. Trying to decide if I want to cover it somehow so I'm curious what your experience was?
post #1142 of 1144
Sorry, been dealing with a family tragedy.
The aluminum is not visible because the frame I made has an overhanging lip that hides the side of the spotlight frame. A couple of other ideas come to mind:
1. You could route a slight recess and set the aluminum frame into it. This couldn't be very deep because the frame would then not open, but even a slight recess would help.
2. Paint or use a couple of layers with a permanent black sharpie to make all the aluminum black. This would probably disguise it enough.
- Paul.
Edited by Moggie - 4/4/14 at 7:09pm
post #1143 of 1144
Moggie,
Family tragedy ...
Thoughts and Prayers to you and yours!
post #1144 of 1144
- Paul.
Thanks for the response Moggie. I ended up wrapping the edge with electrical tape. I hope it stays over the long term.
Sorry to hear that Moggie. Prayers for you and your family.
