It's been a while but I have some progress to share. I finally finished up all the internal framing including screen wall, back bar and rear table/shelf.
The bar outline is inspired by the bar BIGmouthinDC built. Actually inspired is not really the right word I blatantly stole the outline. The curve was cut from some 3/4" sheathing ply and doubled up top and bottom for the plates. The framing is 2x4 with a couple of layers of 1/4" ply laminated together around the curved section. To avoid resonance I filled it with insulation.
Then completed the skinning and prepared it for hardwood veneer.
I still need to add a 5" radius to the left and right returns ala BIG's design.
I also framed in what I'm calling the "Oscar shelf" since that how a friend referred to it when they saw my drawing. The primary function is to hide the rear subs. In keeping with the rest of the theater it is also curved.
I used the same methodology to frame the curved screen wall but I screwed this together rather than use nails because I'm sure I'll have to modify the framing slight after I build my screen and figure out how to mounted it. The wall forms a continuous curve and so at least I've defined the threshold for the carpet. Incidentally I didn't compromise my stage isolation -- the screen wall is not anchored to the side walls and is attached to the ceiling via three DC-04 clips.
The other work I needed to complete before carpet was fitting the hardwood bull nose to the stage and riser. Any woodworkers out there (I'm not one) will probably appreciate just how much work goes into creating custom curves like this, it certainly took me longer than I planned (the carpet shop has been bugging me on when I'll be ready).
Here are a couple of shots of the results after just one coat of shellac. The plan is to add a couple more then, since this is a wear surface, finish with some poly.
I have some picture of the process which I'll post in the next post...
