AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › Sim2 Lumis Owners Thread
Sim2 Lumis Owners Thread - Page 49
post #1441 of 1846
Originally Posted by JlgLaw View Post
The cost of a new 280W LUMIS lamp is $999 from Sim2. The price you mentioned is even below dealer cost.
Jim
Wow. If $695 is below dealer cost, then what is $180 ???
post #1442 of 1846
So is there a "shelf life" on these types of bulbs? Meaning, if I by a few now and in 3 yrs will the last of the batch I bought still be good and of same quality?
post #1443 of 1846
I don't know if these things deteriorate, but the problem is most of these bulbs will come with a 90-day warranty or something like that. If you happen to have a bad bulb, you would have no way of returning it. I think what most people do is just to put in a new bulb right away and keep the old one as a spare. It's probably not worth it to have more than one extra bulb lying around.
post #1444 of 1846
If it IS the same bulb for that price, just goes to indicate the profit taken by the manufacturer ('cause there sure isn't much for the dealer!).
Jim
post #1445 of 1846
Originally Posted by thebland View Post
Can you get this with a cage?
I'd almost like to have a 2nd caged bulb ready to go when I feel like it. Do these outfits sell a cage as well? Not sure where to look...
Unfortunately, no.
The "cage" is a SIM2 proprietary enclosure. Unless another SIM2 product uses the same cage, and you can find someone that some wants to dispose of a used lamp.
Ken Whitcomb
post #1446 of 1846
I'm going to have to try one of these bulbs - the low cost really lowers the per hour operating cost significantly.
post #1447 of 1846
I'm sure I'm on Sim2's sh!t list for pointing out the availability of these replacement bulbs.
Bob
post #1448 of 1846
Bob
And you are on everyone else's GOOD List - until one of the replacement bulks blows up the insides of the projector to smithereens!!!
(KIDDING!)
post #1449 of 1846
Bob
If you disappear we will know who to tell the police to investigate !
post #1450 of 1846
I know bulbs can explode but are the SIM2 bulb cages pretty protective of the rest of the projector?
post #1451 of 1846
Cain ... I doubt you're on their naughty list. On the other hand, I don't think you'll have much luck with warranty work.
post #1452 of 1846
My Lumis (non HOST) refuses to acknowledge the remote and requires pushing the corresponding button on the back panel to wake up from stand-by. On the other hand, the remote would send it to stand-by when pressed. The wording of the manual suggested this behaviour is meant by design... or is it?
Moreover, the last time I watched a movie, the Lumis failed to acknowledge any of the remote and back panel buttons, except for the rocker power switch. I had to hard switch it off, then back on then after a minue or two sent it to stand-by via the remote so the lamp would go through the cooling down process.
Any suggestions to avoid this unpleasnet situation from happening again?
post #1453 of 1846
Call SIM2. Check for latest firmware.
post #1454 of 1846
Switching on/off the Lumis
Try this - I have not had one freeze up or problem since I changed the OSD ( on screen display ) time out setting. Just hit the ESC button to make the menu go away.
I may have found the source of the HOST freezing up - maybe. In the menu the OSD time out comes from the factory ( mine did anyway ) set at 10 ( seconds ). I had Jeff Meier change it to 200 seconds. Hasn't frozen up since. YMMV.
post #1455 of 1846
Thanks Jeff and Craig for the pointers. I'll check the firmware and remember to set the OSD timer next time I fire up the Lumis. Mine was shipped from Sim2 on December '09 so it probably has the latest firmware.
My dealer/friend is visiting with Sim2 this week and I asked him to get me the latest on the Lumis and their product line in general.
post #1456 of 1846
Duh... You have to press the source selection on the remote to wake up the Lumis, not the power button. To send it to stand-by, you use the power button.
Would it have killed them to mention this clearly in the manual?
By the way, my firmware version (December '09 ship date) is 4.01.32 F - 004.
post #1457 of 1846
The $280 bulb is coming tomorrow for my c3X1080. I've got about 1550 hrs on the current one. My plan was to replace it now and then keep the one in there now as a backup. But it still looks very good to me. Should I change it now, or wait? What I'm asking is whether it's bad/dangerous to let it go much past 1500 hrs?
post #1458 of 1846
I'd swap now, just to be sure the new bulb is OK. You know the status of the old one.
post #1459 of 1846
Thanks good point will do.
post #1460 of 1846
Got the bulb today. But it's the wrong one! I ordered from BulbtoGo:
Product: Lamp For OSRAM P-VIP 250/1.0 P22 Projector
But they sent me:
Product: Lamp For OSRAM P-VIP 250/1.3 P22 Projector
Already emailed them about. I wonder if they even sell the 1.0 bulb
post #1461 of 1846
But they sent me:
That's the bulb for my C3X 720. I don't really need another one, but if you get in trouble returning it, PM me.
Bob
post #1462 of 1846
Bob
Thanks. I called them and they do have the 1.0 in stock and are gonna cross ship it out tomorrow. Hopefully this one is right lol!
post #1463 of 1846
I just set up my iPod Touch as a remote to control my projector via TCP/IP using the iRule app. Very cool. Anyone that wants to try this and needs some setup tips let me know.
post #1464 of 1846
Details. Sounds cool.
post #1465 of 1846
Watched 2012 last night. Steaming piece of crap movie.
However, I noticed blacks look a bit crushed. Went through the Spears and Muncil test disc and checked out my black levels, I found after cranking up the brightness I could only see 2 of the 4 bars - none of the below black info.
My Denon BD player was at '0' default BRIGHTNESS. When I cranked up the brightness in my Denon all below black info (4 bars) was visible. So, I left it at +12 BRIGHTNESS in the Denon and lowered the Brightness in my LUMIS to compensate. It appears the LUMIS/HOST was clipping blacks. Whites were OK.
Anyone else notice this? I may update my firmware to the latest to see if this is fixed. I haven't so far as I have been very reliable.
Any ideas?
Currently running 3.14.08 FIRMWARE.
post #1466 of 1846
Any ideas?
Did you try turning off dynamic black on the Lumis?
post #1467 of 1846
No I haven't. It is ON. How could that effect this? Especially since when I change BRIGHTNESS in the Denon player and can see all black??
post #1468 of 1846
It may not make any difference but I can tell you from my own experience that dynamic black reacts differently to different program material and I've usually had to keep it off. Worth a try.
post #1469 of 1846
http://www.avsforum.com/avs-vb/showthread.php?t=1124844
http://www.iruleathome.com/
post #1470 of 1846
Figured it out. There was no change when I went back and turned Dynamic Black on and off.
Brightness needed to be taken off default (in the BD players). Both players originally were clipping the lowest blacks. +1 Brightness in both players fixed it (Oppo and Denon). I had a simialr issue with whites some time ago and moving the contrast to '+1' fixed that as well. Not sure why this is occurring but perhaps my video running through my Halcro SSP has some sort of impact. None the less, it is solved.
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
