Loaded latest firmware. Noticed green push with component inputs (Directv HD DVR). Came on very green then suddenly went off as I changed back and forth between inputs. Not sure if it's fully gone. Reds seemed a bit limp, too. Will check tomorrow. Didn't check HDMI inputs for trouble. Will recheck tonight.
Paged through threw Lumis manual and when I looked at Dynamic Iris explanation, I saw they note that it 'decreases colors'. Well certainly it'll darken things. I, also saw that I can change red (or whatever color) in the USER color management settings by tweaking the y axis. When the projector was calibrated, the initial R/G/B calibrations were done and DVD / BD looks great. HD DVR was difficult to calibrate as their are no internal color setup conterols, etc but has always looked pretty good.
Two things I am going to try to tweak my HD DVR (component input) picture:
1. Turn off Dynamic Iris
2. Set up a User Color Settings and push it a bit red.
Also, can you save Dynamic Iris settings into memory? I tried it with lamp wattage (e.g. 250W for 16:9, 270W for 2.35) but you cannot save lamp wattages into any memory. Changing them for 16:9 and 2.35 has to with individual commands within a remote macro as the Lumis keeps lamp wattages at the last selected.
How are folks here setting up their cable / satellite colors, etc?
But I doubt it will. If anyone knows a place that sells the 1.0 bulb please let me know, otherwise looks like I'll be giving Jason a call.
