Originally Posted by
cal87
In the iPhone/iPod iRule app -
Go to Gateways, Click on the Edit button on the upper right corner.
Under the Network type gateway, select add new gateway.
Enter the name, IP address and port number.
Then connect to device and choose the proper device (the Lumis) under the list. This is the device that you have added/created in the iRule Builder.
Hey Cal. Entered it.
Everything seems right.
But when I go to PANELS, select my LUMIS, the app is trying to connect but comes up with an error message 'F
ailure to connect to gateways"
Now I didn't add a new gateway any where (just the IP and port #)... Am I missing something?
This should work over the ipHone network... not having wifi on.. Any ideas? Thanks for your help.
EDIT: It works over the home's WIFI network but not on the AT&T network
EDIT: Works on WIFI but I think my router is ****-blocking my iPhone from reaching my LUMIS. GOtta punch a hole in my firewall...
Very cool.
