Originally Posted by coldmachine
My own DI became slightly visible a while back, and a hard rest took acre of it.
I only mention this as I was given the following advice, if a straight deselect/reselect of the DB fails to clear the issue.
Assuming the DI is selected and the unit is powered up.... De-select DI and power down the entire unit, including the Host. Disconnect from mains.
Reconnect and power up. Select DB to on. Power down as before, including mains disconnection.
Reconnect and power up. Done.
CM,
What are 'mains' you're referring to? Unplugging the main power cords (HOST and Lumis) from the wall??
I'd like to try this.
