AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › Sim2 Lumis Owners Thread
Sim2 Lumis Owners Thread - Page 60
post #1771 of 1953
Originally Posted by cal87 View Post
I'll send it to you. I think I have your email somewhere. I lost my network control at one point - just reloadiing the firmware restored it (acts like a reset).
Got it! Thanks!
Tell me, does it erase settings or maintains my ISF settings, input names, etc?
Thanks again!
post #1772 of 1953
Originally Posted by thebland View Post
Got it! Thanks!
Thanks again!
Loading firmware does not change any settings. Seems to act like a reset otherwise if the projector seems to be acting funky.
post #1773 of 1953
I see. Easy as pie. Thanks for the help!
Now to try IP control!
post #1774 of 1953
I finally got my lumis this days. I'm very happy with the quality so far but would like to calibrate it - can anyone send (pm) me the code to enter the service menu?
thx a lot
post #1775 of 1953
thx a lot
Access to SIM2 Service Menu: DOT button → INFO button → 66260
post #1776 of 1953
I have a different code for mine.
post #1777 of 1953
thx a lot, worked for me ;-)
do anybody know, if firmware update changes the behaviour of dynamic black - when I use it, I sometimes can see some artefacts and changes in brightness (too easily). firmware is 4.01.30F
have a nice day!
post #1778 of 1953
M(c) it looks like you may want to revert to an older FW version and see if that is the cause or not... unless someone rec's something better I think that is a good first step to troubleshoot.
post #1779 of 1953
after calibration all troubles are gone - picture is awesome! thx for your suggestion anyway ;-)
post #1780 of 1953
M(c) good to hear things worked out. a properly functioning and calibrated Lumis is indeed a sight to behold.
post #1781 of 1953
Originally Posted by gigimonagas View Post
If anyone is interested, I'm selling my Lumis bought from Jason at AVSciene a little over a year ago. The unit is in perfect condition with less than 300 hours on the original bulb. I have the original box and everything. I'm also selling my ISCO III bought at the same time.
Reason: Moving and don't have the space anymore.
Price: Send PM - You won't be disappointed.
Best,
Carlos
Did you sell it already?
post #1782 of 1953
I have 851 hrs on my C3X 1080P . The picture is still bright and beautiful. I am planning to get it ISF calibrated soon. When should I change the bulb,Where do I buy the lamp ?
K.G
post #1783 of 1953
Lamp life is more a function of the number of times it is turned on and off than on the hours it shows on the meter. Good ventilation a cooling is another determining factor. Some people may get a thousand hours or less out of a lamp, while others can get 3K or more. If it is bright enough for you, keep using it. When it comes time to replace the lamp, the dealer that sold you the projector can order the replacement from SIM2.
post #1784 of 1953
I believe he is now keeping it.
post #1785 of 1953
Hi everyone. Has anyone had any trouble installing new firmware? I was having some problem with 3D movies: the 3D image would not project, just a white screen. I called Sim2 and Fausto sent me the latest firmware for my Solo 3D: 5.00.41. (I was using 5.00.28).
When I tried to install it, the first part, the downloader, installed in a few seconds. Then the appcode.hex file tried to install. It would only do 6%, then stopped. Nothing happened for 30 minutes. I finally cancelled out. Now I am not able to start the projector. The power turns on inside, but the light does not come on or the cooling fans. I just hear a faint fan inside, probably on the circuit board. I've tried it multiple times with the same outcome. Sometimes less than 6% installs.
I have to wait until Monday to call Sim2. Hopefully, they can tell me what to do so I don't have to send them the projector. There are a couple of other functions the installer screen: "Verify" and "erase," but I didn't want to try them. Any suggestions?
Thanks, Jeff
post #1786 of 1953
I got the FW to download. The problem was with the Serial-to-USB converter. I tried two without any luck. Finally, I hooked up my old PC with a serial port, and it downloaded just fine.
post #1787 of 1953
Help with my Lumis. What might cause my screen to be VERy dark? I was watching Harry Potter last night and the screen was so dark that we could no longer watch it. When I change aspect ratios, it would go back to normal , but only for a second and then it would return to being very dark. Any toughts on what might cause this would be appreciated. It does this on DVD'd and normal TV.
post #1788 of 1953
How many hours are on your bulb? I had an issue with one of the bulbs. As it aged it started to droop and most of the light was missing the lens.
post #1789 of 1953
Maybe the dynamic iris has gone bad?
post #1790 of 1953
Perhaps the aspect ratio that is dark saved a picture setting that is too dark
post #1791 of 1953
Thanks guys, I have decided to send it back to Sim2 and have completedly gonne thru.
post #1792 of 1953
Does anyone have a sense of what a used C3X 1080 is worth? I know someone that has one and is looking to upgrade to a SOLO.
post #1793 of 1953
Id be interested in this also, what appears to be the guide price for a used c3x1080?
post #1794 of 1953
Depending on what advice you get, I might be interested
post #1795 of 1953
Its only worth a grand. If you're interested call me!
(What type of advise do you expect to get here. Seriously, I've had my C3X 1080 for almost 4 years now and it ain't goin' nowhere!)
Check Videogon to see what used C3X 1080s are going for!
post #1796 of 1953
If I were looking at a used one its price would depend first of all on age (lamp hours), and how well it is converged. Values plummet on big ticket items like these due to lack of warranty and other causes. Price will depend on buyer of course but I'd expect below 50% of original price (not necessarily MSRP) typical, depending on details, and history. Because these are sold regularly heavily discounted new, you have to compare street prices of a new unit and work down from there. If I were buying Steve's (and not his imposter LOL), or Rivercitylad's where I know the person and the history, it would bring a much better price than from a stranger on Audio/Videogon where I know nothing about the unit, how it may have been cared for, etc. Or if I were buying one perfectly converged and freshly serviced at Sim2, that would be a very good one for example.
Short answer, it depends . And Steve, I'll give $2k for yours if it helps .
That said, I'd take a used C3X over some alternatives. But I love 3 chip DLP .
post #1797 of 1953
Hello, i changed the bulb. Can anyone send (pm) me the code to enter the service menu. The Code 66260 don´t work.
Thank you.
web.surf
post #1798 of 1953
Check your pm's.
Bob
post #1799 of 1953
Originally Posted by Citation4444 View Post
Check your pm's.
Bob
Do u mind sharing with me the service menu code for the sim2 3ds?
post #1800 of 1953
I reading over past posts, I ran back across this one. Just curious if you ever got this issue resolved?
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
