AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › Sim2 Lumis Owners Thread
Sim2 Lumis Owners Thread - Page 63
post #1861 of 1953
So Lumis's best / brightest new projector, which I assume is the current 3d-solo on their site, only give around 1100 lumens best case scenario with a new bulb, when calibrated? I need to verify that before moving forward looking into it or writing it off as too dim for my needs.
post #1862 of 1953
There is the new Super Lumis with a 350 watt lamp -
Available in High Brightness (5,000 ANSI Lumens) and Extended Contrast (3,800 ANSI
Lumens) versions. Please specify HB or EC at time of order.
I'm not sure what the calibrated lumens are though.
post #1863 of 1953
Craig sold me a new bulb and I just changed my bulb.
Thanks Craig, 5x brighter than my old bulb!!
How do I reset the lamp timer??
Thx!!
post #1864 of 1953
It's in the service menu.... 66206?? Can't remember the code.
post #1865 of 1953
Thank you, it was an option in the Service Menu, "Lamp Reset" it is now reset to "0"...
post #1866 of 1953
Just curious if any Sim2 owners have tried the Darbee Darblet with their projector and if so, how were the results?
-Mike
post #1867 of 1953
Sim2 C3X 1080 with Lumagen Radiance XE. I have the Darby installed at the projector end and it is amazing!!@@@ Highly recommended.
post #1868 of 1953
Conversely I just removed mine (I have the Sim2 C3X 1080 as well) and marvelled at how much better it is without the Darby. I previously had it set at 50%.
post #1869 of 1953
-Mike
I'm in the minority, but I didn't care for it.
post #1870 of 1953
I agree with the two posts above this one, lasted an hour in my system. Not saying it doesn't help some displays, but I preferred the image without the DD.
Jim
post #1871 of 1953
Seems like about 30% was the consensus "max" to go on the Darbee... I liked the one I tried out in my system with the Sony 1000. It was a friends, though, so it didn't stay.
post #1872 of 1953
I found that when I turned down the C3X 1080 sharpness to 0 that the Darbee improves the picture, but if you leave the sharpness at the prior calibrated setting the Darbee degrades the picture.
post #1873 of 1953
I have an HT5000E and use my Darbee for DirecTV and Netflix streaming only. I never use it for Bluray movies. Even for DTV or Netflix, I keep it below 40%.
post #1874 of 1953
Interesting. I still have the Darby in the chain so I'll try that, thanks.
post #1875 of 1953
I've not seen any time with BD and the 5000 when the Darby doesn't degrade the image.
Art
post #1876 of 1953
I think it improves the picture on my Lumis, but I keep it at 35 - 38%.
post #1877 of 1953
Art
That's why I never use it for BD. It does help the lower quality images from DirecTV and Netflix, IMO.
post #1878 of 1953
thanks for all of the feedback!
post #1879 of 1953
Mike, if you order one from us, and you don't like it, you can send it back for a refund ( minus postage of course ). Give one a try - you have nothing to lose.
post #1880 of 1953
post #1881 of 1953
Originally Posted by biliam1982 View Post
post #1882 of 1953
Cost has nothing to do with it if it did we could have been looking at crt black from digital years ago. bSWme9
post #1883 of 1953
Hello everyone, been so busy, and I've had so few problems with the Erskine rebuild of my HT, that I haven't been on in awhile...
Anyway, I'm having an issue with my Lumis. I turn it on and it stays on for around a minute or two and then the screen just goes black. If I turn it off and restart it the same things just keeps happening. The projector is on and functional for those few minutes before it goes black. Any quick fix for this, before I put in a call to Sim2 next week?
post #1884 of 1953
What's your firmware version (on front display) or OSD (I think)?
How many hours on the bulb?
And if you look at the rear blue LED display on the projector, there should be an error code number flashing when it does so.
post #1885 of 1953
I will check those and post them when I get back from lunch. Thanks!
post #1886 of 1953
Mine did that a couple times and it ended up being the bulb. I had the original bulb in, it was 4 years old and had 600 hours. A new bulb fixed it (and a brighter picture to boot). Installed myself with a bulb from AVS (Craig Peer)>
post #1887 of 1953
When you say the projector goes black, you mean the bulb shuts off but the cooling fans continue to work? Or do you mean the projector shuts down completely - no light, no fans?
post #1888 of 1953
When my bulb was going, that screen would go black but the projector kept running as if nothing was going on and the HOST would lact notmally. Fans running, etc.
post #1889 of 1953
Bland, my question was for QueueCumber - just trying to get clarification on his problem.
post #1890 of 1953
I was aware. Just adding my own previous Lumis issue.
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
