AVS › AVS Forum › A/V Control & Automation › Home Automation › USB-UIRT API Documentation or Tipps
post #1 of 2
i would like to programm the api and find no documentation, i also tried to email USB-Uirt, but did not get a responce.
post #2 of 2
Hi Pharados:
I had the API stuff emailed to me several years ago. The supplied download link, www.usbuirt.com/api_example_code.zip still appears to work. I don't know if its still the latest but its worth a try... It has the DLL, a Help file documenting the DLL, and VB and C# sample programs.
Hope this helps...
- Peter
  Back to Forum: Home Automation
