Originally Posted by
Sonies
Pro tip = you can light up things on your teammates and your screen + minimap by hitting the select button when targetting said object.
Great for those camoflague tanks hiding! I also think you get points if your teammates kill it when its lit up.
Yeah, I've been trying to tell all my squadmates that tip, it helps so much!
I am using the sniper like crazy, I want to unlock the scope which automatically does the "select" button press for you, as soon as they are in your sights, their location is called out to the team.
Headshots are very rewarding, aiming a bit above the head is key, and I love leading a running enemy, and getting the headshot when they are in a full out sprint.. :-D
I have had one freeze up, I was piloting a tank, and in 3rd person view, I was reversing over some chain link fence and it just went black. I had to hold the power button on the console to get the PS3 to turn off. This was particularly infuriating, as I was near the top of the leaderboard that round! Oh well, thats why it's a Beta!
Almost forgot to comment on the mics... They seem to work quite well in squads, however sometimes, if a player leaves the squad, I can still hear them for a while.. Either that or there was a squad bug which made all my squadmates disappear from my squad respawn menu..
