less then 700 hours old (about 2 years though) while watching a movie, popping sound, and unit shutdown.
I checked the lamp which is ok. only the color wheel was shattered.
the unit works fine otherwise (i think).
questions:
I don't live in the US anymore, and I think I'm out of warranty (its been around two years give or take since i got it)
A. anywhere i can check if its still covered under warranty ?
B. where can I buy a new color wheel ?
C. can I install the color wheel myself? I already took the broken one out of its place: When installing a new one, does it require to sync it somehow ? or just insert the wheel and thats it ?
questions:
