AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Olevia 542i Problem - Won't turn on!
post #1 of 3
Like the topic says, the TV won't turn on. I tried wall mounting it, but when I did the TV wouldn't turn on. No red light on the front, and the switch in the back is turned to the correct position. I've tried plugging it in to different outlets and used different power cables to no avail. I hear that the PS unit is a common problem, but I'm not sure how to diagnose this. Also, if the PS is the problem, where could I get one and about how much would it run me? Thanks.
post #2 of 3
bump, please help if you can.
post #3 of 3
Sorry to heard about your problem. Sound like you did all the routine power check to see if the tv would come on. I'm not sure if this would help, but did you make sure the outlets has power (like plug a lamp into the outlets and see if it lights up). And you mention a different power cables was used, meaning the power cable that plugs behind the tv, correct? You can do a search or post your question here http://www.avsforum.com/avs-vb/showthread.php?t=756647 and hopefully one of the members can give some helpful suggestion. Or Google Olevia 4, 5 and 7 series model and see if others units are having the same issue.
