AVS › AVS Forum › Audio › Speakers › How to insulate around in-ceiling speakers?
post #1 of 12
My attic has blown insulation.
I moved the insulation around the areas I put the speakers.
Speakers are installed and sound great.
I want to put insulation back around the speakers, not for sound, but to help with cold air and such. I dont want to push the blown insulation back due to it getting into the speaker or causing a fire somehow.
What is the best way to go about this? Can I just lay a piece of pink fiberglass insulation over it, or cut a hole in a piece and lay it over it?
I am not sure how to do this because I do not know if laying insulation around the speaker or on top of it poses a risk of getting hot and causing a fire.
post #2 of 12
one neat solution
http://www.dynamat.com/products_arch...l_dynabox.html
post #3 of 12
to expensive.
I am looking for just putting a piece of insulaiton up there with a hole cut out or osmething like that.
post #4 of 12
I know it sounds strange, but I had one CI tell me that they have used the styrofoam tomato cages as a backer to the speakers in certain situations. I thought it sounded kind of strange, but I guess it would provide an enclosure and keep insulation out.
post #5 of 12
Heat is not an issue, but obviously you don't want insulation getting jammed in there. If you want to do it on the cheap, I would use regular fiberglass bat insulation. Get some that is at least as thick as the speaker is deep. Take one piece cut a hole & place it around the speaker. Take a second piece & place it over the first. Put blown-in insulation around/on top of that.
-Dave
post #6 of 12
These Pro Wire Insu-Flate ceiling speaker protectors are cheap from PartsExpress and should do the job. Since you have attic access, a shower-cap would work as well.
post #7 of 12
Reviving this old thread. I have the monoprice 4104 that I have blown in insulation resting over top. I assumed it would be designed for this but now am a bit worried. Is there any difference to using the parts express ones over shower caps? I dont want to cheap out but if a shower cap will do just fine, Ill that route. Any thoughts?
post #8 of 12
I have used these in the past. Inexpensive and easy to punch a wire hole through.
post #9 of 12
Just clear the insulation away. It's not going to hurt it.
post #10 of 12
I used a plastic pale from home depot, I stuffed inside with polyfill, then a thick bead of caulking on edge & set it over cut out..it worked great & less than $20. Even improved sound. Just get big enough to go outside a 1"-2" space to clear mounting tabs,you be fine.
post #11 of 12
Well Im having R60 blown into the ceiling (crazy I know), and I wanted to not leave any gaps. I will get some shower caps or styrofoam coolers if that is all that is needed, just didnt know if I needed 40 dollars worth of parts express specially designed speaker bags....
post #12 of 12
I was thinking of getting some 9x9x9 cardboard boxes from Fedex and using those to block the insulation, any reason why this wouldnt work?
  Back to Forum: Speakers
