Alright, finally have a little update for you all.
The kid's play room/lobby is drywalled and the door going into the laundry is installed.
Any suggestion on the concrete wall by the stairs? I want to make the wall as thin as possible.
Looking into the theater.
Sconces for the columns in the theater and the one on top is for the bottom of the stairs.
2 great tools for cutting drywall. First is a "multimax" tool, but it is from harbor freight and was only $35 compared to $100+ for other brands. The other is called a "bladerunner", it has a cutting wheel on both pieces and a really strong magnet. You slide it along the drywall and it cuts both sides at once. Very nice, but pricey at $60.
Theater room looking towards the screen. I removed the riser and have started the insulation and HVAC. Electrical is all run.
The R-30 insulation seems so "raggedy". It seems to not stay together well.
My poor sub, stuck in the other room covered in dust. I miss you!
This is "all" I have left to do.
