I have a Panasonic TH-50PZ80U, a cable DVR, and a ps3 (both connected directly via HDMI) that all works fine. I recently purchased a Sony ct100 soundbar and now run the ps3(and DVR) to the receiver each via HDMI. Now when I toggle inputs on the Sony receiver from DVR back to the ps3, often the ps3 display is all jacked up. The skin tones are blue, things that should be blue are pink, and there is a pink vertical line running the length of the right side of the screen. If I swap back to the DVR input (the DVR input is never a problem) on the ct100 and then back to the ps3, it is often fixed. I've tried 2 different ps3 consoles and received the same results and returned the Sony ct100 for a replacement which does the same thing as well. When the ps3 is connected directly to the same input on the TV it's fine... I've tried all new HDMI cables and every HDMI input on both the TV and the sony receiver. Panasonic tells me they think the Sony Soundbar is incompatible or to try 1080i instead of 1080p even thought all 3 components support 1080p. I'll try that but was curious if anyone has this exact combo and no issues.
AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic TH-50PZ80U issues with Sony CT100 and PS3. Display issues anyone???
