I've read all the threads but the explanations all blur together.
So, I have a JVC RS20, and choosing a screen, and have just got a PS3 but havent hooked it up yet. I was going to do CIH with a lens if I can, Panamorph 480 if I can't.
I'm reading that BR isnt set up ideal for CIH, so what (physically) do you do? Is the use of a lens a bad thing with BR?
Does everyone, even those with lenses, just use the zoom method for BR and the lens for SD DVDs only?
Cant you just make the PJ fill the screen with the image and stretch it with the lens like a SD DVD? If not, what bad happens to the image?
Try to explain in simple terms just what you do when you go from watching hdtv to popping in a BR disc.
