AVS › AVS Forum › HDTV › HDTV Technical › Question about HDMI inputs
post #1 of 2
I apologize if this is not the correct place for this question. I have a Sammy 67inch LED DLP and a Onkyo TX-SR805, my question is, is it better to run HDMI from PS3, HD cable box directly to TV and audio to Onkyo, or just run HDMI to Onkyo and run a single HDMI from Onkyo to TV, is there any significant vieo loss this way
post #2 of 2
Running the HDMI from the PS3 to your receiver should allow you to take advantage of the more advanced audio codecs available on Blu-Ray discs.
HDMI is digital, as long as there's no data loss, the PQ should be the same either way.
  Back to Forum: HDTV Technical
