Any help provided would be greatly appreciated! I had a M&K VX-4 that I essentially sold the driver and amp and kept the box (it's 18x18x12 w 3/4 inch mdf and filled w/ stuffing - Sealed box).
I replaced the driver with a Dayton DVC310-88 rated @ 300w/ch (per vc so 600wpc total) RMS. I have a HiVi Sub250 amp pushing it. The amp is a plate amplifier that came out of a Swan Sub 30. I'm not sure at all of the wattage, but it can't be that much (although the amp looks very beefy and heavy, I think it's around 150 Watts).
When I turn up the volume extremely loud, there is a popping on deep bass notes. I can't see how there is any way a 150w RMS amp could push a 600w subwoofer to it's limit, but it sounds like a speaker bottoming out.
This could also be the amplifier clipping. I don't have another amp to test it with, but I do have older sub's to test with and the "popping" occurs on all of the other subs. Unfortunately, all of the subs are rated for less power than the DVC Dayton, so I can't be sure if it's bottoming out on those and clipping on the Daton. Fewh!
Should I try to sell the amp and get one more powerful? Or does the DVC Dayton just suck. If the DVC sucks, then do all Dayton subs suck - because per their specs, it appears to be one of the best they own.
