AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Kuro - no stand, no wall mount?
post #1 of 9
I will be receiving a new Kuro 6020 next week (hurray!) I want to put it in an antique Japanese cabinet. It will BARELY fit -- IF I remove both the bottom speaker and the stand.
Is it a bad idea to place the Kuro on its bottom edge with the weight of the set pressing down on it? I'm guessing yes, but am wondering if any of you have any experience with that.
Any other ideas on how to make this work in a cabinet?
post #2 of 9
Roberto,
That's just looking for trouble. At best, you might put a wall mount in there, but I don't know how you'd access it to connect it.
Then there is the issue of ventilation. Its got to be able to get plenty of air to keep it cool.
post #3 of 9
If it's a real antique, I'd look to put the TV elsewhere. If not, cut a window out of the back to both provide ventillation and gain access to secure the TV in properly. If it falls out in six months, you'll have to go buy a Panny.
post #4 of 9
Ouch -- don't even joke about it falling out
Given the size of the panel and the shape of the cabinet, there's no way for it to fall out the front. So all I would have to do is add a couple of blocks in the back to prevent it from falling backwards. The back of the cabinet IS open, so access isn't a problem and it would have plenty of room for air flow.
BUT all of the weight would be on the bottom edge of the panel which doesn't sound like a great idea. The alternative like Jim mentioned would be to put a wall mount in the back, but having a solid back and enclosed top and bottom wouldn't give it any ventilation.
So I don't know. Maybe it's out with the old (the antique) and in with the new (the Kuro)
post #5 of 9
Roberto,
Post a jpg of the cabinet. Maybe we can figure something out for you.
post #6 of 9
Not a good idea. I don't even know how you would get it in the cabinet. It is over 100lbs.
post #7 of 9
If you can get in from the back, I suppose you could build a cage out of 2X4s and put bolts through into the back of the TV. (Where the wall mount brackets attach.) This would take the weight off the TV cabinet, but I'd think the frustration of trying to get it to work properly, and the proximity of a power saw that you made the cage with, could lead to a news headline.
post #8 of 9
I'm pretty sure I can get the TV into the cabinet. And after looking at the product manual, I could probably mount it on a couple vertical pieces of wood to provide the necessary support.
I guess the biggest question is ventilation. Like I mentioned, the back of the cabinet is open, so there would be a couple of feet of air space BEHIND the TV. Unfortunately, there's only about 3/4" between the TV and the top of the cabinet, so not much there. But there are a couple of 1/4" gaps in the top of the cabinet that would allow *some* heat to dissipate.
I guess I'm just not sure whether you need open air behind AND above the set (or if it's enough to just have space behind it). Anyone have their Kuro mounted INSIDE a wall?
post #9 of 9
Roberto,
1, Resting the 6020 on its bottom is not a good idea at all. The install instruction even tells you to lift the panel using the recess handle on the back of the tv instead of lifting the bottom. It is just not designed to support the weight.
2, You need at least 19 11/16 inch of space above the tv for proper ventilation. Remember heat rises unless I guess if you have active cooling (fan) on the back of your cabinet.
For the above 2 references, go to page 15 of the 6020 Operating Instructions.
Again, it's your money, your tv, do whatever you want with it.
