AVS › AVS Forum › Audio › Receivers, Amps, and Processors › need receiver that can switch a/b speakers with remote?
post #1 of 4
Any new AV receivers capable of switching a/b speakers via remote? I run different speakers for movies and 2-channel music listening, would be cool to get my Logitech Harmony to select the right speakers when it changes activities...
post #2 of 4
A/B switching is definitely in the harmony database for Denons. I imagine many other brands have them too.
post #3 of 4
Thankyou. I'll have to add Denon back to my list then. The Yamaha 863 I've been testing out will not do it, apparently. The suit and tie I talked to at Magnolia didn't think the Pioneer Elites would do it either (and couldn't find a remote to test it). Haven't looked at Onkyo yet.
post #4 of 4
Sometimes the IR code exists even though it is not on the original remotes. And IR codes are generally consistent within a brand. For example, the current Denon 1909/789 model does not have an A/B speaker switch on the remote, however previous Denon remotes do have this command. So if you can get the IR code it will work for any Denon model.
I am willing to bet the same thing applies to the Yammy 863. You may be able to track down the IR code for A/B speaker switch even if it's not on the actual remote.
