I've seen occasional references to this model, but no thread, so I thought I'd start one, hoping someone can help me with a few questions about the DMR EA38V. I've had a number of panasonic DVD-recorders over the years and just got a new panasonic TV, but this model DVD + VCR has me stumped on a few fronts.
First, I knew it was tunerless when I bought it, but ... because I have cable, I assumed that would be okay. What I did not realize is that there is no antenna in option so there was no place to "plug in" the cable if you don't use a secondary box. I was trying to AVOID cable boxes because I want to be able to do multiple unattended recordings -- didn't want to have to switch channels manually. Anyway, I have an old vcr and an old DVD recorder (neither of which reliably record any longer) so I put my trusty old panasonic DVD-recorder to work on the LINE 2 input,acting as a tuner .
Initially I was going to run the cable through the DVD recorder to my new panasonic LCD TV (model TC-26LX85 -- which, by the way, I adore). Signal seemed compromised, so I split the cable and put one Coax directly into TV, the other into the halfdead DVD recorder, and fed that into the new tunerless EA38v line 2. So far so good. I also added a DTV converter box hooked up to an antenna, so I could get higher quality over the air signal (better than my comcast feed) for certain PBS stations and fed that into line 1. Thought the 'two' input options might give me more channel options, but now that I have it working (sort of ) not sure that's the case.
I'm beginning to think that getting a tunerless DVD recorder was a stupid idea. I cannot figure out how to activate the Viera auto channel download (what are these channels downloading TO?) , nor can I figure out how to activate the Viera RECORD NOW function. It's advertised as able to record the channel you are watching on TV on the DVD-recorder, but I can't seem to get that option to work. I'm obviously doing something wrong, or the advertising is inaccurate for this model, or (possibly?) that it only works if you're using a cable box. Can someone please enlighten me as to how to get the full viera feature to work. Right now the tv and dvd recorder are talking to each other a bit (I can start PLAYING a dvd directly from the TV control and it knows when I insert a DVD to play -- but I just cannot trigger the RECORD NOW function. It's grayed out.
Any ideas? Also, had some remote control conflicts (three panasonic machines in close proximity)and I had to change the remote codes (*so I could do a channel scan of the OLD dvd recorder tuner) but I left the new DVD-recorder and TV on the same remote code, thinking that might enable the viera. Still no luck.
I'm thinking I may need to either return this model for one with a tuner (I bought this one because the EZ line has had such crummy reviews and the EA were (in theory) better....
Maybe it needs the firmware update? Or ...??? Maybe it only works properly with a cable box? I know that will disable my ability to do remote recording - as I understand it, you need to set the box to the channel in order to get the DVD-recorder to record. No more unattended multiple recordings? That seems like a huge trade off.
I'd appreciate any thoughts on this. I haven't tried recording VCR to DVD yet, but the off the air recording (line 1) and the old tuner to DVD recorded fine too (not a great signal that way, though) So I don't HATE it, just have been hitting my head against the wall trying to figure out why it's so complicated -- when usually Panasonic machines are fairly straightforward. Can anyone at least clarify the VIERA part of the mystery? I'll work through the cable connection options myself through trial & error. thanks!
the Panny is the bedroom TV
Will try again...
