Originally Posted by
MississippiMan
I have to jump in and state for the record that I feel Mica-based DIY Mixes....of all varieties....are far more capable of adjustment than those containing the "Aluminum" element.
Back in 2003 at the beginning of my DIY Screen endeavors, Tryg's own expose' as well as the reported accounts of "most" users were basically negative in scope. There existed too many "issues" concerning Aluminum's tendency to Hot Spot, to create "Visible Granularity", difficulty in application even when mixed w/other paint, and the sourcing of an applicable "Aluminum Base".
Interesting, recently I thought you said it was 30 years experience, but that's beside the point, this is after all a 'discussion'.
I too have seen the archives. Back then there were many issues with a wide variety of things, including what constitutes a true neutral gray.
Aluminum it self will hot spot. There is no denying that. It may be a very very good option for the guys at LumenLab though because they aren't dealing with the extremely bright projectors that are readily available to everyone today. As far as 'Visible Granularity', you'll get that with any particle that's has too large of a flake size, yes even mica if it's too large.
Difficult to apply? Not really. No more so than any other more advanced DIY method, in fact it's easier than some out there that require a very specific amount of coats, sprayed at the exact precise distance... and also the mix must be precise as well or there could be a color imbalance. It's neither harder or easier than most, but is easier than some.
While it may be true that some may have to source the Createx, I've also seen some that had to special order some of the mica ingredients out there. It is widely available at either Michaels or custom auto paint shops in most areas. If the goal is something that works exceptionally well, then ordering online is the last concern I'd have since it only takes a couple of days extra
if it can't be sourced locally.
Going back to 2003 though. Most were trying to use aerosol spray paints, or those that were using metallics were not using actual aluminum, rather mica metallics. For the few that I saw that did find and try actual aluminum, they were using much lower percentages than I tried and they also threw in other ingredients such as other mica's and polyurethane and many other components. That is a totally different approach. So yes aluminum was tried by some, but not in the exact same way.
It can also be said that back when you advocated clay based ceiling paints rolled with an 18" wide roller and completely admonished spraying in anyway that others were using micas and spraying screens at that time too. It doesn't mean you didn't come up with something unique and have a different twist to the application, but you certainly were not the first... same as I wasn't the first to ever use aluminum. The difference as I mentioned is how it was used and applied as a screen.
MississippiMan
The latter was resolved by use of "User opened Spray cans" of Rustoleum Aluminum Paint. However many attempts were made to mix the Rustoleum with UPW and roll it on, much like what is done today with an application like Black Widow. Results were so very "spotty", (...a statement both tongue-in-cheek and dead on serious...) the use of that application was almost nil.
Again, great example of history. I too saw those early threads and it wasn't the best way to go about things. That I will agree with you on. Also and again my opinion... part of the problem was trying to mix a water based latex with an aerosol based spray paint. It was a good thought and if taken to the next level who knows where we'd be right now? Thing is they dropped it even though it showed promise.
The problem was trying to figure out how to harness it, which, to some people's dismay and dislike is where science comes in handy.
MississippiMan
Honestly, IMO...Benven's CG-Brand of DIY Paints were more successful at obtaining high gain results that also provided Aluminum's ability to enhance Colors and projected Blacks... and being so very high gain they actually could "compete against" not merely "joust" with Ambient Light.
The CG methods certainly were interesting, but also some of the most complex mixes I've seen. Again the amount of aluminum used as a fraction of what I used, as well as having numerous other components added. The question really is what component was adding what to the total mix? Since it was mostly mica and poly, that is what attributed to the sheen, i.e. gain. I do have to give benven credit because he departed from using standard craft paint quality micas and was using very good quality artist paints and micas. They were extremely small particle sizes, and did not refract light nearly as much as all the other methods I've seen back then (and now too). Too bad he felt brow beated back then to have continued with those. BTW, I wasn't the one doing the brow beating, I wasn't even a member at that time. Anyone interested, just search the archives, it's all in there for prosperity.
There were some interesting ideas, but perhaps a lack of focus or even confidence for the developer to continue.
MississippiMan
But ONLY if you maintained a seating position almost directly "Dead Center". There were of course some advocates for that sort of performance because many had (...and still have...) limited space / seating area. These were the people left to choosing between a DaLite HP and a similarly performing DIY application (CGIII)
That's simply gain. Any screen (including yours) are subjected to the properties of gain. I did see some claims though of a 1.8 screen that had a 180 degree viewing cone and you maintained that was an absolute truth. I'd still like to see the explanation and science behind that one!
(You can't create more light than what was originally produced by the projector. You can only 'borrow' light from off angle and focus it back towards the viewer... i.e. increased gain and reduced viewing cone. That's simply the physics of light is all and again nothing I just made up)
MississippiMan
Screen "PoP & Sizzle" never becomes more pronounced than it does when Aluminum or Silver is in play. I pursued "Silver" because of it's controllable reflectivity, so much so that it could be increased proportionally as to the performance gains, but without introducing unwanted side effects.
Honest question... When you say 'Silver', are you actually talking about silver itself or a silver metallic mica? Depending on your answer will mean a lot. Silver and Aluminum are very similar and aluminum is even used as a true silver substitute. They are both controllable if the proper methods are used, and both being non-interference methods there really is no unwanted side effects introduced aside from hot spotting if it's used as the only ingredient.
MississippiMan
Still, throughout the ensuing time frame, many approached even Silver-based mixes with a "More just has to be Better" outlook. Not workable. Essentially, without achieving the "balance" necessary between reflectivity and a "masking effect", Silver will exhibit much if not all of the bad habits of Aluminum. But it's a little more forgiving, and so it takes a bit more determination to "muck it up".
Again, what exactly are we talking about here, can you be precise and more specific?
As far as being more forgiving, I guess we really need to nail down what you are talking about. If you are talking about a silver powder, or pure silver based paint... then that would seem to be very expensive and I've seen even you say the sourcing for Createx Aluminum was too expensive for people to consider as an option.
I'm just trying to fully understand what it is you are talking about when you say 'Silver'. Again though, if it really is silver, then it isn't any more forgiving than aluminum, just more expensive.
MississippiMan
So Silver it was/is for me. But even then I was actually overly cautious. Prior experiences by many others with Aluminum and Silver made me utilize "less than more". But that served me well as far as getting a gradual knowledge and acceptance of it's proper usage. Since Behr's Silver Metallic Faux Paint had what was considered at the time as having the finest SM particles, it was the medium of choice. But it also was a very dark Gray hued Silver Metallic, so only 1 oz maximum per quart was ever considered being in the acceptable range of use. Otherwise, granularity and sparklies could & would become present, chiefly because when such a dark gray surface was infused with shiny particles, they stood out more than they helped. However, that caveat was restricted to the darker but reflective Silver Metallic. Think tens of Thousands of little mirrors turning on-off axis continually while being interspersed within a white base medium. When the mirror goes "off', it leaves a "Black Spot"" that actually shines in much the same manner as a particle whose reflective surface is facing "on axis' to the viewer. Only differently.
Maurice forgive me, I am being sincere when I say I am also a historian of screens and have spent months in the archives as well. I may not have joined AVS back when you first did, but I do my research.
Forgive me but I don't ever recall you playing around with aluminum. Back in the day you went from rolling ceiling paint, to hooking up with pb and then being a convert to spraying and micas. I never really recall you playing around with aluminum or other non-interference methods. Perhaps you did in the background and then abandoned them, I honestly don't know. But I really don't recall all this extensive use of aluminum and non-interference methods.
Again, if you abandoned them, it was probably because back then there was no science or specs known about them. I know you hate data and a scientific approach, but I feel this is both an art as well as a science. I also personally use both, but never totally push one over the other. I am just curious because you are talking about history and all your involvement and everything you've tried but I just don't recall you ever talking about aluminum. It's an honest request to see those archives.
Also, why did you abandon them? aluminum reflects more than mica, that's again simple physics. If a medium allows any light to pass through it, energy is lost. When energy is lost, the reflected light isn't as bright. I will be open minded and say that may not be perceivable by the naked eye, but then again it just might be. It would have to actually be measured. I'll leave that up to you though because in another thread you stated you will be conclusively be proving all of this. We've already done some of this testing, I'm just interested in seeing how you are testing and coming up with the conclusive proof. No harm no foul... just curious to see one colleague's results and proof is all. Nothing more intended there than I am very interested in your insights.
MissippiMan
But that is why Silver (...and aluminum...) make such apparent improvements in rendered contrast. How much and how well does one or the other do such magic in comparison to the other though....that is what needs to be ascertained here.
Again, can we get some clarification of exactly what this 'Silver' is you keep mentioning? If it is Behr Silver Metallic, you're really talking apples to bananas because the are totally different things.
This is a very interesting lesson in AVS DIY screen history. History though doesn't always mean something is factual or proven, just that it's 'history'.
I am very interested in seeing your old tests between silver and aluminum. I can't stress this enough... that is a very sincere request and I honestly am interested. Again, think if we knew then what we know now!
Oh... sorry, this is a 'debate/discussion' and one were aluminum/non-interference methods and science are going to be proven as insignificant. Still, I mean it when I ask, I am interested and if everyone can learn and we can improve things... even better!
MississippiMan
to be continued.....
...........and it is.
I applaud the creativity and effort that went into refining a Tinted base to help compensate for the dark "Graying" tendency of Aluminum when it's mixed into a White...or near white paint. It's having advocates that were also formally proponents of neutral Grays (...but who at that time disdained the use of metallics.....) who used known tint blending methods to create a beige-tinted base that in turn when combined with the "Gray' base containing the Aluminum resulted in a nearly neutral finished Mix.
I also applaud the efforts of others in their applications. Everything builds on other endeavors and experiences.
Actually the 'known' tint blending methods aren't so known. I haven't fully disclosed the key to balancing anything out to a true D65 neutral. That may sound bad or even arrogant, but seeing that so many other things came under fire and the people taking the shots always seem to 'know better', I was just curious to see if they could explain the same method, and even more important to me... why they use it.
As far as being 'nearly neutral', well it's a dead on bullseye. Without actual readings and all those charts and graphs that you dislike though, it would just be one person making a claim and 'saying so'. That's why I use data to back things up, but make no mistake, I also use the exact same real world testing and empirical testing that you also do. I am just not sure how including the actual data, readings, and specs are a bad thing since that's not the only thing being shown. If it was, then I would be on your side and say just because something may have the numbers doesn't mean it actually works, but again... both are shown. Is that really a bad thing to show people?
Before anything is said that there is a demand that everyone has to do all this and show the numbers... nope, never said that at all. Just when someone else makes some very hard line claims and states their method is the best of the best and nothing else is close... well, then yes I'd like to see all of the information and not just subjective screen shots as the only proof. In those instances I don't ask anyone to do anything I haven't provided myself.
MississippiMan
PB-Maxx and I did it the hard way.....by using separate primary colors, both flat and metallic-infused Red-Blue-Green-yellow, to create a variety of Gray Hues, Grays that we obtained by adjusting the amount of a pre-determined Color Mix that was added into a reflective White base. In doing it so, a quantum leap in the percentage per volume of Silver AND Pearlecent Mica in any such mix could be achieved.
In private I have said how impressive it is what you and pb have done solely by eye. I however don't fully agree with the methods and claims because they don't agree with known color science. They may be an artists eye view, but to say that's ideal isn't looking at the full 'picture' (pun intended). The problem with doing things by eye is everyone sees things differently. What you may like may not be what someone else likes. This is exactly why I am an advocate of D65 neutral when it comes to gray. If it is not neutral, then it is a color, and if it is a color then as a screen it will have a push. If the user happens to like the same color push (cool or warm) as the developer that did things by eye, then everything is fine. If they like something different, well then they may or may not be able to compensate and calibrate to the temperature they prefer. If the screen is D65 neutral though, then the user has the option of leaving it at D65 to see exactly what the director wanted people to see... or they can make the image warm or cool- but to their liking and not dependent on the screen itself.
Where I think people are missing the mark is that there is such a wide variance between how two people see things, and the human eye, as incredible as it is, also depends on our brain and what we were 'taught' colors should look like to be able to say a human being can look at a color and tell if it is neutral or a color
they think is neutral. That's where all those readings you dislike come into play. By using a spectrophotometer (and I know Prof55 is familiar with them) a person can actually see the values and then plot them on a known chart with very specific reference points. Depending on where they plot will indicate whether it is neutral, or has a color push. Anyone that can do this by eye... well, that's pretty amazing and they might want to contact Ripley's!
The rest is the history and explanation of your mixes, and I will not interject on those comments. I just felt the comments about aluminum vs. mica (and yes some of the history lesson) needed a point/counter-point perspective. I fully explained why and how Black Widow was developed as well as why I used aluminum. You're questioning that application and all the bandwidth the supporting data has taken up, but I'm not going to claim to know why you did things the way you did. Only you know that and that's what we'd love to see... why and how was things determined. Right now, the only thing I've seen anywhere is that it's been done by an 'artists' eye, and that's fine. It's just when the claims come into play that one is more neutral than the other, or more reflective, or better balanced and more 'adjustable', or has a higher gain, or flat out said it's better than everything (but why does it always change if it's better?)... well people generally do want to see the supporting data to back things up.
MississippiMan
The very nature of the use of varied components within a mix like Silver Fire allows for almost infinite adjust-ability, but certainly far more within the desired range than that of a Mix whose aluminum is limited to far less concentrations, and that even then it will darken any mix far in excess to that concentration's ability to "optimally" utilize the reflectivity quotient inherent in Aluminum.
In that sense, the much hurrah'ed aspect of perfect neutrality becomes a side issue. Any "Gray" can become neutral with the efforts employed by those who pursue such. But not any "Gray" can support the addition of too much of a particular Reflective element....or too little.
Again, I honestly do not recall your extensive use and testing of non-interference methods as you are implying you have. If I missed something, then I truly regret not seeing that work because it would have been very interesting. But to say Silver Fire is almost infinitely adjustable and a non-interference method isn't, well that I don't agree with or understand your logic. I really would like to see the comparison where you've tried it and came to the determination it didn't, or couldn't work... which is how I read your comments.
D65 neutral gray is not something to be passed off as something bad.
"Any "Gray" can become neutral with the efforts employed by those who pursue such."
I would be very interested in seeing how you balance things out and know for certain they actually are neutral. Actually I think many would be interested in that. You show and explain how you're doing it as well as show the supporting readings to prove it is indeed neutral when you tell everyone it is, and I'll fully disclose my method I mentioned earlier in this post.
Sounds more than fair to me! I know our method works, so before I talk, I'd love to see your explanation and proof. (Again, you were pretty firm and confident in another thread that you were going to conclusively prove everything once and for all... which will be very informative once that happens I am sure
"But not any "Gray" can support the addition of too much of a particular Reflective element....or too little."
Actually, that's something I will agree with you on.
MississippiMan
A study again of the complete Silver Fire mixture is needed to show the differences between it and other DIY mixes that are designed with the same intentions in mind. Look at the concentrations of metallics in the various component mixes, and the overall Mix itself. Do the math. Make comparisons with "other' DIY paint apps. See the light.
You said it brother! The archives are jam packed with a bazillion requests of just that! I'm really glad you finally decided to explain everything once and for all!
MississippiMan
Materials available at Michaels Arts & Crafts or most any Artist Supply or Hobby Store.
"SILVER FIRE"
* use 3 oz. of the 'color components' and add/mix it to the 'base & viscosity components'
(base components)
24 oz. Delta Ceramcoat Pearl #02601 @Michaels
16 oz. Delta Ceramcoat Silver Metallic #02603 @Michaels
8 oz. Behr Interior UPW Flat #1050 (or Exterior.#4050) @ Home Depot
6 oz. Delta Pale Metallic Gold #02624 @Michaels
(viscosity components)
24 oz. Minwax Polycrylic - Satin Finish @Michaels & Home Depot
10 oz. Distilled / Tap Water "NO" Filtered OK.
(color components)
60 ml (2 oz) Distilled / Tap Water
60 ml (2 oz) Delta Pale Metallic Gold #02624 @Michaels
30 ml Delta Cardinal Red #02077 @Michaels
16 ml**** Windsor & Newtwon "Galleria" - Pthalo Green (PG7) @Michaels
12 ml**** Delta Ultra Blue #02038 @Michaels
****Changed to offset occasional over-mixing errors resulting in green / blue push. Although a very small drop of the amount of the "Grey's color depth results, more neutrality is achieved. These components are critical, and also have the smallest measurable portions. Unless one grossly undershoots the prescribed amounts, a small degree of overage to the stated amounts will only bring the mix back to it's original level, not "push' it into an adverse hue.
The "Found @ Michaels" ingredients might be, and probably are available at Hobby Lobby.
Silver Fire - L (Lite)**
** use 2 oz. of the 'color components' and add/mix it to the 'base & viscosity components'
Silver Fire - SL (SuperLite)***
*** use 1 oz. of the 'color components' and add/mix it to the 'base & viscosity components'
"SILVER FIRE HG" (High Gain)****
(base components)
36 oz. Delta Ceramcoat Pearl #02601
12 oz. Delta Ceramcoat Silver Metallic #02603
8 oz. Delta Pale Metallic Gold #02624
7 oz. Behr Interior UPW Flat #1050 (or Exterior #4050)
same as above
(color components)
same as above
**** use only .75oz of color components.
Folk Art -Champaign Gold Metallic- is the replacement for the Delta Pale Metallic Gold
PG7 (P)Thalo green is a "Primary Color" and does not have to be a "W&N" product. It virtually always comes in a "Tube" not a bottle, and is located in the Artists Acrylic "Tube Paint" Dept. in Artists Craft stores.
Many times, the chief weapon employed against the use of Silver Fire is it's supposed complexity, and the difficulty of obtaining and mixing the various components. But it all boils down to actual results....based upon it's flexibility of design and usage...and if one wants the best possible results.
certainly those who lay upon the fringes of the need for ambient light performance can consider a lighter screen. But why does one have to give up the redeeming qualities of a Silver & Pearlecent metallic medium simply because ambient issues are non existant? Its well known that most all "Dark Room" Theater owners are loath to consider a Gray Screen. yet many still want the advantages that a Gray brings to any equation. Enhanced Colors. Deeper Blacks. More perceived Contrast. (...the latter is what make the former two possible...)
But ya know, for some years now, a great many such people have had no adverse compunction in considering any of the several variations on the theme of MMud-MaxxMudd-Silver Fire, and complimenting Light Fusion DIY applications. For certain the lack of gain, perceived or otherwise, was never a overriding issue, nor was Color reproduction or Black rendering, screen texture-granularity, or ambient light performance. Everyone a criteria by which to judge a DIY screen app's usefulness. How much more so is an app's usefulness if such a application can do all of those things...do them all well...and be adjustable from being as dark as required without adversely affecting the image quality (under correct conditions) to as light as needed while still delivering the performance qualities of a "Gray Screen"?
Next up: Is Mica as poor a reflective medium in comparison to aluminum as it's been made out to be?
Mica is a very good reflective medium, it just refacts light is all because it is an iridescence. I however will be very interested in your insight and knowledge to explain this and why everyone else is wrong about iridescence and why they are used. Does it reflect light? you bet. Can it be sparklie? Another you bet. Is it perfect and has no energy loss and no prism effect? Well... mica is mica and does what mica does. Unless you know something the experts don't. I just can't see how it can be the characteristics of mica can be argued about as if it is something that was made up. Can it be used? Sure... but like I said, lots of things can be used.
Maurice, one thing I really would like to ask though is to actually back up what you say. I can,will, and have on my part... please do the same since you said this was going to end the debate once and for all.
