Originally Posted by
drkdiggler
Has anyone run into any heat issues ...
Is there any way (zip ties, etc) to attach something like
this 40mm Scythe fan for $3.45 (jab-tech.com)? As beautiful as the Thermalright chipset coolers are, it might be easier (and cheaper!) to add a small fan.
mythmaster
Do you have "Adjust refresh rate" enabled in video player settings?
If I remember correctly, I looked at that I remember it being un-checked.
By the way, another slight issue I encountered is that XBMC wants to use the desktop refresh rate
reported by gnome - regardless of the actual refresh rate (as reported by nvidia-settings). nVidia knows about this
and offers this workaround:
Why is the refresh rate not reported correctly by utilities that use the XRandR X extension (e.g., the GNOME "Screen Resolution Preferences" panel, `xrandr -q`, etc)?
You can use `nvidia-settings -q RefreshRate` to query the actual refresh rate on each display device.
This behavior can be disabled by setting the X configuration option "DynamicTwinView" to FALSE.
In my case, although nvidia-settings (and my monitor) reported 60Hz, gnome thought 50Hz. Thus, the default mode in XBMC was 1680x1050 @50Hz. After adding the above line to xorg.conf, gnome and XBMC both say 60Hz.
