AVS › AVS Forum › Blu-ray & HD DVD › Dual Format Players › BH200 Audio out
BH200 Audio out
post #1 of 7
I just updated to the latest firmware and can't get anything beyond 5.1 from Gladiator or 3:10 to Yuma.
Stargate and Top Gun give me 6.1.
I'm feeding a NAD M15 from the spdif optical.
Any help is much appreciated
post #2 of 7
It is because you are using SPDIF, it cannot carry lossless formats, often the Legact DTS/DD tracks are 5.1 only. Your BH200 is behaving correctly.
post #3 of 7
Does that mean that you can only get lossless from HDMI or analog? Is that a BH200 limitation or SPDIF thing?
I'll have to check the manual but my M15 will only receive audio on spdif and I believe it claims to decode DTSES yet it does not receive audio from hdmi.
Thanks for the help.
post #4 of 7
It's an SPDIF thing, and yes, lossless is only over HDMI or analog.
post #5 of 7
Well that's the pits! I got the M15 recently and the purveyor who is generally very trustworthy assured me it would do everything.
Since I don't expect NAD to do any updates to the M15 it seems like the only solution is a new receiver.
post #6 of 7
SPIDF was designed before there was such a thing as lossless multichannel surround audio, nevermind before higher definition audio. The bandwidth is far beyond the spec.
Yeah, sucks. I never had SPIDF audio drop out, but I have over HDMI.
post #7 of 7
How does it sound? DTS 1.5Mbps is pretty damn good, and as noted, audio dropouts are almost non-existent with it. I have it on one of my BH200's and have never had a dropout. Just watched Casino Royale last night, sounds epic... the lossless remix to DTS works pretty well.
  Back to Forum: Dual Format Players
