AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › KRP-500M or Pioneer PRO 111FD?
KRP-500M or Pioneer PRO 111FD? - Page 4
post #91 of 99
You can get a brand new 500M for around the same price. Maybe less.
post #92 of 99
Originally Posted by kuro123 View Post
I can get a open box 111fd without TV stand for $1800. Should I buy it or KRP-500m? Your advice is appreciated.
I was in the same predicament as you. BB had a open box but it was a demo 111fd, looked great but was on over a year for 12+ hours a day. No point in paying that whne you can get a 500m new with stand for the same price
post #93 of 99
Originally Posted by Marty1781 View Post
The cable box is the tuner, so your setup would work just fine with the 500M. You would need a tuner in the tv, for example, if you wanted to watch tv without the use of a cablebox. The 500M does not have an internal tuner so you will always need to use some sort of external OTA, satellite, or cable tuner (like a cablebox) in order to watch television with it.
Pardon my ignorance,but does the 500m have a connection for coax? I do not have a cable box per say in the house. Our coax is brought in from the street
where the "cable box" is(underground utilities). I.e., we don't have a cable box on top of the tv that the cable company provides. This is how I currently get my cable. I have tried checking Pioneers website for a detailed back view of the 500m, but was unsuccessful. Based on the other responses, I know I would need to get a tuner and speakers. Debating this unit before they become extinct! TIA.
post #94 of 99
Nope, a coax connection would indicate the presence of a tuner and since the 500M does not have a tuner, it therefore does not have a coax connection. You are able to plug the cable via coax directly into your current tv and watch tv now because your current tv has a tuner but again, the 500M does not have a tuner/coax connection. Without a builtin tuner, you need an external tuner such as a Tivo or a cable box from your cable company to do the work of tuning in the channel and then pass it along to the monitor/500M.
post #95 of 99
Does the 500M have powered speaker outputs?
I've seen some places selling the 500 with the side pioneer speaker add ons. Can the set drive these without a seperate reciever?
post #96 of 99
Yes. The Pioneer KRP-500M has stereo speaker outputs, rated at 9W@6ohms per channel. You're not limited to using the matching Pioneer side speakers, either. Until I get around to buying a surround sound setup, I'm using these in the meantime. They sound better than any of the built-in speakers on any of my previous TVs.
http://www.amazon.com/Pyle-PCB3BK-10...9027115&sr=8-1
post #97 of 99
Interesting speakers. Are those self powered?
post #98 of 99
No, they are not self powered.
post #99 of 99
hey man,
I need the pedestal stand for my pro-111fd. will pay Cash COD or if you need to sell the speakers as well I might be able to take them off ur hands!
let me know if you still have them.
thanx
